Hi all,
Regrettably I have to sell my car due to moving overseas (to NZ). I have owned this car for a little over 1 year now and since then have hardly had the opportunity to drive it. It was off the road for most of the time while I replaced the engine and added a few extra bits. Sadly now it must go to a new home. The paint/body work could use some t.l.c but could be a lot worse. I would love to restore it to it’s former glory but sadly can’t.
The car was imported from Japan in 2005. I am the 3rd owner since it arrived. The 1st 2 were brothers. Bought the car with 107,000 km’s on the clock and I've put a total of 3,500km. So barely been used in the last 12 months.
I am looking for any interest in buying the car as is. It is currently unregistered but was previously registered in QLD. I recently moved to Sydney and haven’t had it rego’d yet. I did have a mechanic check it over before moving down here and a few bits need fixing (some worn bushings and a gearbox mount). I have most of the bits needed to fix it and they will come with the car.
1989 R32 Nissan Skyline GTR
Roughly 110,500 km’s on the car
Roughly 75,000 km’s on the replacement engine. Came from a ’94 R32 GTR front cut. (The old engine oil pump broke and engine seized).
Twin HKS 2350 turbos
Mines 600cc fuel injectors
Mines Air Flow Meters
Genuine Mines Tuned ECU (can come with Apexi Power FC and Hand controller for $800 more)
Autobarn88 600x300x100 FMIC with hard piping kit inc. HKS front pipe
Twin Blitz BOVs
HKS throttle body gasket (also have exhaust gasket never fitted)
Bosch 040 in-tank fuel pump
Apexi style air pods
Extended Sump
Standard internals
Oil filter relocation kit with HKS oil filter.
Autobarn88 Silicon hose to replace all heater hoses and radiator hoses
Brand new fuel filter
Brand new Water, Power Steering, A/C Belts.
Brand new NPC 5 puck organic clutch and lightened flywheel to suit cost $1200, also replaced clutch release bearing at the same time as well pedal very light but awesome grip.
3” Veilside Evolution II cat back exhaust (very nice noise, not too loud. Can come with spare exhaust that was originally on the car. Straight pipe from cat to back 3.5”)
Modena Racing 17x9J Alloys with near new rubber (Tyre make and model)
Aftermarket fiberglass Side skirts, not sure what brand but they are cracked and could do with being replaced/repaired.
Tein adjustable suspension.
Brand new upgraded slotted and drilled brake discs front and back with new pads.
JIC racing front upper control arms
HKS Turbo timer
GRID HICAS electronic lock out
Greddy Boost controller
Trust boost guage
Black Widow alarm and immobilizer with remote central locking (was fitted when I purchased car)
Alpine head unit with removable face and remote control
Recaro drivers seat (was worn/torn and now patched, see pic)
Momo steering wheel.
The only thing really wrong with this car might be the paint work, it’s a bit ptchy on the spoiler and there are a couple of scratches here and there but to be expected from a 24 year old car…
I think that is about it but I may have missed something.
I also have some other spare parts that can come with the car: brand new adjustable cam gears, brand new Gates racing timing belt, Apexi Power FC with hand controller, 3.5” straight pipe exhaust (very light), “twin turbo” pipe + more…
Car is located in Sydney (2114)
Viewing welcomed/encouraged.
Looking for around $16k as is where is or I will be looking for $17.5k when I have time to get it back on the road.
Contact 0406188865 for viewing/questions.
Many Thanks.
Will get pics up this evening...
https://www.sau.com.au/forums/topic/419395-eoi-1989-r32-gtr-syd/
  • 3 weeks later...
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
