Hey guys, I've just started wrecking a white series 2 R33 Skyline Gts-t here in Sydney.
It was running great before it went for a slide on a wet night and the front corner and rear quarter licked a guard rail
Chuck me a message or reply here if you're after anything - it had some dead sexy wheels and a few mods listed below:
Pickup fine in Sydney or I can send most parts anywhere in Australia
post-35556-0-62431100-1360126947_thumb.jpg post-35556-0-71167200-1360126966_thumb.jpg post-35556-0-67637500-1360128006_thumb.jpg
Aftermarket stuff:
Set of 4x Enkei AME Circlar Spec R matte black wheels and tyres - $2200 ono
Fronts are 18x9" +15 offset, rears are 18x10" +15 offset. Fits R33 gts-t without spacers and looks great, perfect for GTRs also
Tyres are Federal SS595 all round, stretched 225/40 on the front and 235/40 on the rears. Lots of tread left - 70%+
All the rims are in immaculate condition, basically no gutter scrapes to speak of at all. No stains on the silver or scratches on the black centres
post-35556-0-87489300-1360127017_thumb.jpg post-35556-0-70239200-1360127079_thumb.jpg post-35556-0-03173500-1360127091_thumb.jpg post-35556-0-08582000-1360127150_thumb.jpg
post-35556-0-55394300-1360127029_thumb.jpg post-35556-0-17191300-1360127036_thumb.jpg post-35556-0-81501700-1360127055_thumb.jpg post-35556-0-65771400-1360127063_thumb.jpg
Kics Racing Composite R40 - Wheel Nuts & lock nut set. Great condition, looked awesome on the above wheels - $100 ono
BC BR height and damper adjustable coilover set, includes C-spanners. As new condition, weren't in the car long - $900 ono
post-35556-0-96443100-1360127282_thumb.jpg post-35556-0-13133900-1360127291_thumb.jpg post-35556-0-13652600-1360127299_thumb.jpg
Hardrace adjustable front castor/tension rods. Great condition - $120 ono
Hardrace adjustable upper camber arms. Great condition - $120 ono
Nardi deep corn 350mm steering wheel + HKB bosskit (airbag/hicas compatible) & horn. $250
Immaculate condition, like new, was only used for a couple of months before the car stacked it. Have the receipt ($375 for wheel alone) and box
post-35556-0-51258800-1360127649_thumb.jpg post-35556-0-78498000-1360127684_thumb.jpg post-35556-0-70658700-1360127693_thumb.jpg
Cooling pro stealth return flow FMIC & polished piping kit, suits R33 Gts-t & R34 GT-T
Good condition, includes all pipes and hose clamps/joints. Small ding/scratch on one side, does not affect anything - $350 - pickup only
post-35556-0-41282100-1360127734_thumb.jpg post-35556-0-10750800-1360127805_thumb.jpg
Splitfire coil packs (SF-DIS-005) suits Series 1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Triple gauge cluster with smoked-face Auto Gauge gauges (boost, oil temp, water temp) Looks great lit up - $150
clips/fits right into the R33 Gts-t dash into a DIN slot. Includes all wiring, hose, water temp sensor. Second photo is with the flash on so you can see the faces
post-35556-0-35573400-1360128411_thumb.jpg post-35556-0-83920000-1360128418_thumb.jpg
Monza Oil Catch can - $40
Apexi pod filter, bolts right up to most Nissan AFM - $50
The engine has approx 120,000k's on the clock and ran great. Timing belt was replaced by Unigroup at ~94,000km in 2010
I did a compression test this week and it came up great - 150-155psi on all cylinders - chasing $1k ono for the bare engine (no turbo, coils, accessories, etc)
5 speed manual gearbox was running great as well, shifted nicely. Regularly serviced along with the engine - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc
Exterior Stuff:
headlights, front bar, reo not available
s2 front bar foglights/inducators (white) - $120 pair ono
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & rear pods - $150
boot lid & s2 spoiler, immaculate condition - $150
Engine / Engine bay stuff:
Aircon condenser - $150
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $100
Series 2 (no ignitor) Rb25det engine loom - $150
S2 afm (pink sticker) - $90
Engine Mounts - $70/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Standard fuel pump - $40
Brakes/driveline:
Front calipers, with basically brand new pads - $280
Rear calipers, with basically brand new pads - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea ono
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
S2 Front seats, great condition, small bit of wear on the driver's side in the usual area - $120 - pickup only
Complete set of S2 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 120,000km, all gauges working - $120
Instrument cluster dash surround - $100
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
  • 4 weeks later...
  • 5 weeks later...
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
