Hello all.
Hope 2013 finds you well.
I have read a lot about owners believing that there was a magic percentage of 25%, for drivetrain losses, to allow a conversion from flywheel kW to wheel kW in a RWD platform.
I had always thought this was bunk.
Was suprised to compare two dyno sheets from my car over a three year period.
The 25% was pretty close.
Maybe it's just my car though.
Attached is a spreadsheet which progressively matched the dyno runs.
This is NOT the gospel, it's just what happened for my car.
Jim
KW to HPx.pdf
https://www.sau.com.au/forums/topic/419425-r34-gtt-fwkw-to-rwkw/
Oh noes!! :no:
I think this will go on for a few pages. Those who mistakenly believe that there is a fixed percentage will get increasingly angry at those who believe there is a relatively fixed loss (with a very small increase in losses due to friction etc as power levels rise).
IBTL
I say the "losses" are largely at the tyre/roller interface (it's the only place where you can liberate 50 - 200 HP where there is sufficient cooling to take the heat away). And in general, on a DD dyno, it's about 25% (including the real losses in the drivetrain, however small they are).
so, pray tell, how did you get flywheel power readings from after you've upped le boost?
Hi xALmoN
Hope all is well.
The FW power noted, is only approximate.
It was proportioned to the original dyno run, when stock.
We slotted in the originally claimed 206FlyWkW, with a 154.4 RWkW actual dyno run, and kept the ratios the same all the way down the chart.
The interesting outcome, was keeping the same percentage of FWkW to RWkW on the second dyno run, resulted in exactly the right amount of RWkW.
Don't forget please, that I only posted this as a result for my car only. Not a gospel on how to convert FWkW to RWkW.
To be honest, there is so much involved in that conversion, I would have no hope of figuring it out (I'm a bit challenged)
It was just an interesting result.
What could actually be happening here is that the FlyWkW is going up or down faster as the power increases, and I wouldn't know it.
I think that the fact that a 'fixed percentage' can be debunked by eventual melting of gearboxes when you're in the 1000s of HP is a fairly certain indicator that it's not correct.
Perhaps for a given gearbox design, it's a percentage loss until a certain point? Who f**king cares anyway.
Subscribed :)
Look forward to checking this after work.
I generally tell ppl the Hp I make at thd wheels is about the kw it makes at the flywheel. While I don't believe its a fixed percentage most ppl are just looking for a number to compare to their car and its close enough and they have no idea what their car makes on a dyno so its much easier
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
