Captain Natro Posted February 8, 2013 Share Posted February 8, 2013 Can confirm factory N/A goodness. Plain gts. Did they come with boost/oil pressure in the dash? Boost no, oil pressure yes... Also sitting tightly waiting the pics of the 32, you did send them to me back when I had my rb but I deleted the message Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742453 Share on other sites More sharing options...
foxy boxy Posted February 8, 2013 Author Share Posted February 8, 2013 Turbo dash threw me off. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742472 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 Alright guys, if you want to naturally boost an N/A, follow my write up. It should look something like this: The throttle body is harder to get photos of, as it's further up inside the front bar after a hard pipe coming from the intercooler, but it's very self explanatory. Pod > intercooler > throttle body > piping > car throttle body Don't forget to gut the AFM and lay all your parts out and make sure you have enough silicone joiners and things like that to make it work. Post up your pics! Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742543 Share on other sites More sharing options...
emts Posted February 8, 2013 Share Posted February 8, 2013 Whoever connected that pod filter should be shot. putting the hose clamp on the hard pod filter base pushing down on the soft flexible silicon!!! smallest back fire and that pod filter is going to launch off. hell get a nice hot day with the silicon softening and it could well drop straight off. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742566 Share on other sites More sharing options...
Captain Natro Posted February 8, 2013 Share Posted February 8, 2013 Yer that's the one I was thinking of, that looks bloody neat as If I didn't have to hack up my front bar I'd probley put one on my ls setup.... Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742577 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 Whoever connected that pod filter should be shot. putting the hose clamp on the hard pod filter base pushing down on the soft flexible silicon!!! smallest back fire and that pod filter is going to launch off. hell get a nice hot day with the silicon softening and it could well drop straight off. You're an idiot... There is a hard pipe piece in between the pod and the coupler, it isn't clamping down on silicone! Plus, the throttle body prevents a backfire coming back through the intercooler. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742578 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 FWIW, this car has been running reliably for a few months now. I'll post a dyno sheet. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742599 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 Dyno sheet before and after, the red line is without the intercooled setup and the green is the intercooled setup. Names have been cut out. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742610 Share on other sites More sharing options...
emts Posted February 8, 2013 Share Posted February 8, 2013 got a sound clip of tb2 opening? Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742625 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 got a sound clip of tb2 opening? How? The intercooler won't fill up with air if the car is stationary and I don't intend on hanging off the front of the car risking my life just to record a sound clip for someone who has nothing positive to say, anyway. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742635 Share on other sites More sharing options...
Hanaldo Posted February 8, 2013 Share Posted February 8, 2013 Good son of rajab... Kwaka... I am just going to sit here and applaud. Why I never thought of cooling ambient air with ambient air is just a kick in the nuts. And I spent all that money on turbocharging my car. You sir... You know your spanner from your shifter. Any other advice on getting power from an NA? Shaving weight off the cams for example? 1 Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742642 Share on other sites More sharing options...
Hattori Hanzo 69 Posted February 8, 2013 Share Posted February 8, 2013 what the actual f**k you were serious Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742657 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 (edited) Good son of rajab... Kwaka... I am just going to sit here and applaud. Why I never thought of cooling ambient air with ambient air is just a kick in the nuts. And I spent all that money on turbocharging my car. You sir... You know your spanner from your shifter. Any other advice on getting power from an NA? Shaving weight off the cams for example? Weight can definitely be shaved off cams by taking material off the cam lobes, unless you know what you're doing though, you shouldn't do it. Valve timing becomes affected. You didn't waste your money turboing your car, I'm just enlightening everyone to the fact that there's more than one way to skin a cat. 177rwkw in a light 20DE GTS is pretty fun! Edited February 8, 2013 by kawasakirider Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742668 Share on other sites More sharing options...
emts Posted February 8, 2013 Share Posted February 8, 2013 How? The intercooler won't fill up with air if the car is stationary and I don't intend on hanging off the front of the car risking my life just to record a sound clip for someone who has nothing positive to say, anyway. you never heard of go pro hanging off the car...such a newbie Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742669 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 what the actual f**k you were serious The proof is in the dyno sheets my man. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742670 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 (edited) you never heard of go pro hanging off the car...such a newbie I'm a newbie yet you don't know how to intercool an N/A car? I have heard of a go pro, but have you heard of background noise? The throttle body opening isn't as audible as say, someone hitting gate. The noise is definitely audible but not to that extent. I might get him to do a fly by later. Plus, I don't have a go pro. Idk why you need to hear it when you can see it and the dyno sheet is there. Edited February 8, 2013 by kawasakirider Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742671 Share on other sites More sharing options...
34GeeTeeTee Posted February 8, 2013 Share Posted February 8, 2013 I'm a newbie yet you don't know how to intercool an N/A car? I have heard of a go pro, but have you heard of background noise? The throttle body opening isn't as audible as say, someone hitting gate. The noise is definitely audible but not to that extent. I might get him to do a fly by later. Plus, I don't have a go pro. Idk why you need to hear it when you can see it and the dyno sheet is there. If i run twin throttle bodies will i get 12psi? If so, i might ditch the 3076 setup and go with that! Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742675 Share on other sites More sharing options...
kawasakirider Posted February 8, 2013 Share Posted February 8, 2013 If i run twin throttle bodies will i get 12psi? If so, i might ditch the 3076 setup and go with that! Not quite, Matt. Since there's no "forced" induction, you're really relying upon ambient air getting a bit sped up as the throttle body opens. Adding a second one will just slow it all down and probably have a negative effect. You could get a greater effect on an N/A zed with two intercoolers and two intakes on the same plenum, but that's another story. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742682 Share on other sites More sharing options...
34GeeTeeTee Posted February 8, 2013 Share Posted February 8, 2013 Not quite, Matt. Since there's no "forced" induction, you're really relying upon ambient air getting a bit sped up as the throttle body opens. Adding a second one will just slow it all down and probably have a negative effect. You could get a greater effect on an N/A zed with two intercoolers and two intakes on the same plenum, but that's another story. Well based on that i reckon a flat intake with ITB off a GTR would easily be the best option? You could fab them into the end tank? Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742692 Share on other sites More sharing options...
emts Posted February 8, 2013 Share Posted February 8, 2013 I'm a newbie yet you don't know how to intercool an N/A car? I have heard of a go pro, but have you heard of background noise? The throttle body opening isn't as audible as say, someone hitting gate. The noise is definitely audible but not to that extent. I might get him to do a fly by later. Plus, I don't have a go pro. Idk why you need to hear it when you can see it and the dyno sheet is there. with my last NA i was too poor to go to this much effort, I used to just open up the airbox and dump a bag of ice in there, so long as you put drain holes worked a treat.. Link to comment https://www.sau.com.au/forums/topic/419429-front-mount-intercooler-in-a-na-worth-it/page/4/#findComment-6742695 Share on other sites More sharing options...
