hi all
i am looking at converting my r31 skyline to rb20det and i can get hold of a Redtop Nics version For Cheaps with loom etc....
now i have a question
Are the RB20DET Redtop And Silvertop Exhaust Manifolds the Same?
both have a T3 Style Flange??
if i buy a custom exhaust manifold of a silver top eccs will it bolt up to the redtop NICS motor?
i know they are probably pretty slow standard but i looking at getting a front mount etc....
thanks for your input all :)
https://www.sau.com.au/forums/topic/41943-rb20det-nics-v-eccs/
yes they are the same except that the silver top one makes about 10kw more than the red top... if you search for it you might find out some stuff..
i think they both have the smae size turbo but different and a few other little things..
do a search and find out.
NICS engine had a slightly different head to accommodate variable inlet runner lengths. This is achieved by having 2 inlet ports, one of which had a butterfly to open / close the port. Problem was the butterfly eventually gave up and jammed, so the engine ran like a dog.
I believe you can bolt the ECCS head on, but by the time you've done all that, you might as well have spent a few extra $ on a ECCS engine.
What lets the nics down is the size of the turbo, it's tiny. Stock turbo on my coupe is 8psi but by the time you reach 7000rpm it drops to 5.5psi. Thats with 3 inch exhaust with custom dump and K&N pod filter. Once you replace the turbo it produces alright power.
The thing that lets down the nics rb20 is the ecu, with an r33 turbo bolted on, you can only run about 11-12psi max as the ecu starts overfueling like crazy.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
