hey everyone, i pulled into my drive way the other night and my car died, i checked the battery and the terminal was of so i puth them back on and started the car back up, procced to try and drive and it would not accelerate no matter what i done, as soon as i touch the accerate the car splutters and stalls out,
here is what i have tried so we dont go over things twice :)
- tried diffrent AFMs
- tried a new TPS
- searched for any vaccum leaks for hours
heres a little about my car so no one has to ask what it has ect
- Standard rebuild (Short motor assembled by Hypertune Engine and Mechanical)
- ACL Race bearings.
- Chromoly piston rings.
- Block and all internals were acid bathed, cleaned, bores honed.
- Crank was Linished. Crank Collar was machined onto the nose of the Crank.
- N1 Oil pump and crank collar installed.
- New Timing belt, tensioner pully and water pump installed.
- Head reconditioned by Gilberts head recos with high quality valve stem seals.
- HKS adjustable cam gears installed.
- Alloy RB26 sump modified for RWD.
- 600x300x100 Front mount intercooler installed.
- aftermarket turbo intake piping kit.
- Apexi split dumps, Apexi 3inch front pipes, Catco high flow cat, 3inch Apexi Stainless catback with muffler. (Apexi N1 catback)
-no bov, stock turbos, stock ecu, stock AFMs
thanks for your time please please try and answer my question i really need some help! thanks
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
