Hi all...
Been off here a while now. Good to be back.
Quick question, if you have the stock basic gauges (instrument cluster) are you able to upgrade to the premium model?
http://www.ebay.com/itm/03-07-INFINITI-G35-AUTOMATIC-SPEEDOMETER-OEM-/200821103813?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec1dedcc5&vxp=mtr
That one to be exact.
Ta much
https://www.sau.com.au/forums/topic/419469-03-07-gauge-upgrade/
you guys might want to have a read of this thread......http://g35driver.com/forums/lighting/99235-put-05-06-gauge-cluster-my-03-a.html
and if you can't be bothered, this pic tells a thousand words.....
Just guessing, but I don't think it is probably as bad as that pic suggests.. by the look of it, the mess of wires is just someone's home made adaptor cable with connectors for the S1 harness on one end and connectors for the S2 cluster on the other end.. if you can get the correct connectors, the service manuals and some good multicore cable, I am sure you could make up your own adaptors that look much nicer..
Still not a nice 'plug and play' job though..
yeah for sure, the thread basically talks about how he paid for an auto elec to come up with a solution to get the S2 gauge working in his S1 and that was the result. He did a bit of work to make it neater, but it still comes down to the fact that you need to rewire everything.
I have done a little bit of wiring in my time, and learned a few things as I have gone along, but there is no way in hell I would take on that job. To get that many things working perfectly (and lets be honest, what's the point of a gauge that doesn't work perfectly?) would be a literal nightmare. A job best left for the pros, and it would not be cheap!
besides - this would be much cooler.....
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
