Hi guys
Got some more R33 GTS-T parts...
Let me know asap if you are interested in anything as the early bird gets the worm...
If you are serious about a part, you will call or text me,
as I don’t come on here anymore due to parting out my whole skyline.
So topic posts and my inbox will be responded with great delay (or not attended to at all). I’m very easy and honest to deal with, so contact me by phone.
Low-ballers and time wasters will be ignored & possible delivery at buyers expense.
All parts can only be picked up from Reservoir 3073 or Brunswick 3057 in VICTORIA
I will be very firm with my prices.
- RB25 Gearbox
- Came off a series1 R33 GTST -
Was is my car, works fine
$900
- Greddy forward facing plenium
with
90mm throttle body
, only in car for 500kms
$650
post-62246-0-34574300-1360195633_thumb.jpgpost-62246-0-59804700-1360195728_thumb.jpgpost-62246-0-80131800-1360195818_thumb.jpgpost-62246-0-43293500-1360195908_thumb.jpg
Want both? Package = $1400
- BILSTEIN ADJUSTABLE SHOCKERS WITH APEXI SPRINGS
, have not even travelled 3,000kms (car was mainly off the road as a project) Never used for track, all adjusted to a nice ride high, firm but still comfortable ride. Ready for use! Just bolt them in Great condition!
$750
post-62246-0-28807100-1360197317_thumb.jpgpost-62246-0-46745600-1360197344_thumb.jpgpost-62246-0-79778700-1360197360_thumb.jpgpost-62246-0-17576300-1360197370_thumb.jpgpost-62246-0-51504700-1360197386_thumb.jpg
- Drive Shaft
for manual gear box -
$100
- 3 inch Stainless steel High flow ca
t, minimal use, Can be polished to look new, 2,000kms
$50
- 3 inch dump pipe,
repaired at top, fits on factory turbo to cat
$30
- 3 inch exhaust
(after cat) with
4 inch muffler
(copy of apexi exhaust) Sounds great!
$250
post-62246-0-14062200-1360197867_thumb.jpgpost-62246-0-02017400-1360197859_thumb.jpgpost-62246-0-09047000-1360197880_thumb.jpgpost-62246-0-70903100-1360197885_thumb.jpg
- Silencer
for 4 inch muffler
$20
Want the full exhaust set up? Package = $300
R33 Tail lights
, pair
$30
- Series 2 factory headlights
, great condition
$300
post-62246-0-23484700-1360198224_thumb.jpgpost-62246-0-86296700-1360198233_thumb.jpgpost-62246-0-05156900-1360198240_thumb.jpgpost-62246-0-13348200-1360198252_thumb.jpgpost-62246-0-40172600-1360198267_thumb.jpgpost-62246-0-95065000-1360198282_thumb.jpg
Series 2 factory front grille, great condition,
dirty in picture
$20
- SET/PAIR series 2 indicator/fog lights and cover $100
- SET/PAIR side mirrors great condition, cobwebs in pictures $20
- Series 1 dash
(no airbag) excellent condition
$20
- Series 1 factory steering wheel
heavily worn, great for Roadworthy’s
$10
- Series 2 rear parcel shelf
(excellent condition, took me ages to find one in such good nick, no holes in speaker grille/cover)
will also fit in Series 1 $40
CALL OR SMS NOW TO AVOID DISAPPOINTMENT!
Speak to you soon
Ben 0422 782 888
Just as sounds a carpet rugs ad! ;)
On a serious note, would lights fit a GTR and would you take $200?
I don't think they will fit, due to panels being different sizes. You would need to search around for more information. $300 flat price.
  • 4 weeks later...
UPDATE!!! SEE BELOW FOR PARTS THAT HAVE BEEN MADE EVEN CHEAPER!!! GRAB A BARGAIN!!!...
Once again, I will be very firm with my prices.
CHEAPER - RB25 Gearbox - Came off a series1 R33 GTST - Was is my car, works fine, no clutch - ONLY $600
SOLD - Greddy forward facing plenium with 90mm throttle body, only in car for 500kms!
CHEAPER - BILSTEIN ADJUSTABLE SHOCKERS WITH APEXI SPRINGS, have not even travelled 3,000kms (car was mainly off the road as a project) Never used for track, all adjusted to a nice ride high, firm but still comfortable ride. Ready for use! Just bolt them in Great condition! ONLY $600 BARGAIN!!!
attachicon.gifIMG_0260 (800x600).jpgattachicon.gifIMG_0263 (800x600).jpgattachicon.gifIMG_0261 (800x600).jpgattachicon.gifIMG_0262 (800x600).jpgattachicon.gifIMG_0264 (800x600).jpg
SOLD - Drive Shaft for manual gear box
- 3 inch Stainless steel High flow cat, minimal use, Can be polished to look new, 2,000kms $50
- 3 inch dump pipe, repaired at top, fits on factory turbo to cat $20
- 3 inch exhaust (after cat) with 4 inch muffler (copy of apexi exhaust) Sounds great! $200
attachicon.gifIMG_0270 (800x600).jpgattachicon.gifIMG_0273 (800x600).jpgattachicon.gifIMG_0271 (800x600).jpgattachicon.gifIMG_0272 (600x800).jpg
- Silencer for 4 inch muffler $10
CHEAPER - Want the full exhaust set up? Package = ONLY $250
CHEAPER - R33 Tail lights, pair ONLY $20
SOLD - Series 2 factory headlights, great condition
SOLD - Series 2 factory front grille, great condition, dirty in picture
CHEAPER - SET/PAIR series 2 indicator/fog lights and cover ONLY $60
SOLD - Series 1 dash (no airbag) excellent condition
- Series 1 factory steering wheel heavily worn, great for Roadworthy’s $10
CHEAPER - Series 2 rear parcel shelf (excellent condition, took me ages to find one in such good nick, no holes in speaker grille/cover) will also fit in Series 1 ONLY $30
CALL OR SMS NOW TO GRAB A BARGAIN!!!
Speak to you soon
Ben 0422 782 888
  • 1 month later...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
