  • Replies 239
I got your PM Kent. :yes:
That's not very nice :/
Also bit of feedback shirts look awesome and are good quality only problem if had is i ordered a large and its slightly to big.... So next time ill grab a medium :)
Thanks for the feedback. :)
Glad that you're happy with the quality. In regards to size, may have a solution.
EAT A STEAK!
All of the shirts are a little generously sized. If we use this supplier for the next batch then we know to order a smaller size than normal. They must be US sizes....
Yes big fat fatty sizes... I can't wait to see Chris in his 3XL :rofl:
I could always use any other one though, maybe black this time :yes:
Zeke got 2 L's. I wanna see these 3XLs they'll be like tents on the boys.
Way to go bursting my bubble. My 14 is huge on me, was telling myself that I'd lost weight. I did order a larger size so I can wear a long sleeve under it during winter
I like my shirts over sized. My problem is the lenght is never long enough for me
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump veins have seized or that there is a perished seal somewhere??
    • No idea. It's too weird.
    • The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
    • I searched , but did not find what I need, I am mainly looking for where the jack fits into bracket in rear left trunk/fender bracket on a GTT and what holds it in place.
