Howdy,
I have a car taking up room in my carport as well as a heap of other bits and pieces so everything must go ASAP to make some room!!!
It's a white R33 skyline series 1 1993-1995 with series 2 1996-1997 parts also available as well as random RB30 bits which I have collected over the years!! All prices negotiable, but please no time wasters, if you need anything just post or PM! I dont bite!!
Located in Blacktown minutes off M4, M7 and 10 minutes from M2 I can post at buyer expense depending on what it is.
Prices listed below, will post up additional pics as soon as I pull everything off, all bits are in good working condition unless stated otherwise, if you have concerns please just ask.
GT3071R Ball bearing Turbo w/ internal wastage and actuator Kit which includes:
  • Includes braided oil line
  • Custom 4 inch intake pipe with provisions to match all factory R33 intake pipe
  • BLITZ pod filter
  • Adaptor plate
  • Xforce high flow dump pipe and o2 sensor
  • Great condition perfect blades and no shaft play 10 000kms old - spools up great no lag on RB25 - good for 290rwkw $1,500
Turbo specs verified by GCG -
  • Ball bearing
  • Oil & water cooled
  • T25 turbine inlet flange
  • 5 Bolt turbine outlet flange
  • 400hp - 450hp
  • 0.86a/r Turbine Housing
  • 0.50a/r Compressor Housing
  • 4" Compressor Inlet
  • 2" Compressor Outlet
  • HKS GT2835R Equivalent
Manual box R33 Turbo 5 speed box - great condition shifted perfectly - $1,100
R33 Engine RB25DET, long motor with no bolt-ons - 150 000kms - ran great - $1,000
HKS Genuine Super drager muffler 3inch system inc hi flow CAT and 2 mufflers mid way - excellent condition - sounded tough but not too loud - nice and quiet, can be made louder by removing muffler - $500
Series 2 front Bar - slight dent on front and pre cut for cooler $150
Series 2 headlight left good condition $300
Series 2 headlight right good condition $300
Series 2 reo $100
Wolf ECU - $500
Blitz 850cc Injectors in stock rail - $450
GFB Blow OFF Valve with RB adaptor plate - plumb back or trumpet changable - volume adjustable/plumback adjustable at the turn of a dial - $220
16 inch R32 GTST wheels and tyres 90% tread $450
Series 2 Bonnet - straight as - perfect - $400
17x7 inch wheels and tyres 80% tread $300
HYBRID Front mount intercooler kit - needs a clean/polish $100
UNDERODY - brakes suspension etc.
Front callipers $270
Rear 5 stud hubs $120
Handbrake setup $150
Manual LSD 4:11 tight $200
Driveshafts $180
Stock suspension $150
Rear callipers $140
Front strut brace aftermaket CUSCO? $100
Front lower control arms pair $100
Front rotors $50
Rear rotors $50
Castor rods $50
Front 5 stud hubs $50
Rear lower control arms $50
BODY
Spacesaver $40
Side skirts custom $120
Rear pods $100
Front windscreen $100
Left foggies/blinker $80
Rear windscreen $80
Front guard left $60
Front guard right $60
Door Rubbers full set $70
Series 2 Grill $50
Rear wing series 2 style but a little taller aftermarket? $50
Quarter windows $50
Front door windows $50
Mirrors $40
Tail light left $40
Tail light right $40
Rear garnish $40
Bootlid $40
GTST Badges $40
Genuine Nissan Scissor Jack $40
Mirrors $40
Left Door $30
Right Door $30
Rear bumper $30
Wipers and motors $30
ENGINE BAY
Manual Conversion bits $200
Air con compressor $120
Polished Surge tank setup with Bosch 040 pump $120
OEM Coilpacks $100
S1 engine loom $100
Steering rack $100
Sard Fuel Pressure Regulator FPR with gauge $100
Power steer rack $80
Radiator $80
Tailshaft $80
Engine mounts $70
Alternator $70
Brake master cylinder $60
Radiator shroud $40
Power Steer bottle and hoses $40
Washer bottle $20
Radiator overflow bottle $20
Fuse box lid $20
RB25 Exhaust manifold $100
INTERIOR
Dash cluster 150xxxkms - worked perfect $120
Drivers side window motor $100
Jap steering boss kit and AUTOTECHNICA wheel $100
Boot trims complete - need a clean$100
Instrument cluster with vents $80
Seatbelts $80
Floor mats front 2 only in checkered series 2 style $80
Ignition barrell and locks $80
Drivers side window switch $60
S1 Door trims and quarter trims - slight marks $50
Passeneger side window motor $50
Series 1 Front seats $50
Steering column surround $50
Gear selector surround and boot $40
Center console $40
Climate control unit $30
Rear seat $30
Rear parcel shelf/child restraints/factory speaker grill $30
Indicator switch $20
Wiper switch $20
Cheers!
Hey mate, do you have the cabin fan available?
do you meant he black on for the AC? and if so yes $40? give me a call or sms 0402*842*180
Are the injectors for rb25?
Yes they are for rb25 in rb25 rail with plugs and everything to plug and play
Hey mate im after the bare doors if theres not dents or scratches and drivers power window switch if its good condition...
have all of them to give me a call or sms 0402*842*180
Boot trims $100 comes with everything
Excedy heavy duty clutch Sports tuff
Near new barely used taking out of parted vehicle, also inlcuding fresh machined flywheel $450 for the lot ONO
Polished Surge tank setup with Bosch 040 pump, comes with all wiring relay and ready to plug and play - fits perfect behind back seats in R33 $120
Complete wreck available!
Sold all below
Turbo kit - still have dump pipe to fit stock turbo
Left headlight
Left foggy blinker
Wiper motor
Grill
Strut brace
Boot trims
hi mate will take the surge tank setup can you give me a call tomorow sometime to sort out payment and postage. cheers 0403423121 Dean
Will do
Injectors still available
