Sold the following:
rear bar
boot lid
left foggy
left headlight
boot trim
raidus rods
front lower control arms
SARD FPR
centre console
Heaps of performance bits still available as well as Complete RB25
WOLF V500 Direct plug in ECU for RB25DET R33 - $500, take it away! The current model of this ECU retails at $1,995.80 incl GST:
http://wolfmotorspor...3-gtst-plug-in/
This ECU is a direct plug in ecu which plugs into factory harness - no chopping harnesses or piggy backing harnesses, very clean installation capable of producing great results.
Inludes laptop plug - great condition, like new, also ran great when installed in the car - removed from parted vehicle which was not smashed or damaged at all
Spec attached in pdf. file attached below.
Wolf_V500_Specification_Sheet1.pdf
hey, how you going with that fuel pump and surge kit, is it still available?
Hey
In tank pump still available, surge kit setup is sold.
Cheers
Many parts still available complete clean R33 series 1 interior and body panels will create list soon
Hey
Cheers
Did you find out what kind of pump it is? Also how much?
Still available below! prices very negotiable!
HKS Super Drager CAT back was $500 now $300
Clutch Kit $200
Series 2 front Bar - slight dent on front and pre cut for cooler $150
Series 2 headlight right good condition $300
Series 2 reo $100
post-30339-0-80235100-1360219532_thumb.j
Blitz 850cc Injectors in stock rail - $450
16 inch R32 GTST wheels and tyres 90% tread $450
Series 2 Bonnet - straight as - perfect - $400
17x7 inch wheels and tyres 80% tread $300
post-30339-0-10499500-1360219648_thumb.j
Front callipers $270 $100
Rear 5 stud hubs $120
Manual LSD 4:11 tight $200
Driveshafts $180
Stock suspension $150 $80
Front rotors $50
Front 5 stud hubs $50
Rear lower control arms $50
post-30339-0-76123500-1360219563_thumb.j
post-30339-0-67879800-1360219593_thumb.j
post-30339-0-51298400-1360219629_thumb.j
Side skirts custom $120 $80
Front windscreen $100
Rear windscreen $80
Front guard left $60
Front guard right $60
Door Rubbers full set $70
Rear wing series 2 style but a little taller aftermarket? $50
Quarter windows $50
Front door windows $50
Mirrors $40
Tail light left $40
Tail light right $40
Rear garnish $40
GTST Badges $40
Left Door $30
Right Door $30
Wipers and motors $30
Misc Manual Conversion bits $200
Air con compressor $120
OEM Coilpacks $100
S1 engine loom $100
Cross member $80
Power steer rack $80
Radiator $80
Engine mounts $70
Alternator $70
Power Steer bottle and hoses $40
Radiator overflow bottle $20
Fuse box lid $20
RB25 Exhaust manifold $50
post-30339-0-70982000-1360219662_thumb.j
Dash cluster 150xxxkms - worked perfect $120
Drivers side window motor $100
Jap steering boss kit and AUTOTECHNICA wheel $100
Instrument cluster with vents $80
Seatbelts $80
Ignition barrell and locks $80
Drivers side window switch $60
S1 Door trims and quarter trims - slight marks $50
Passeneger side window motor $50
Series 1 Front seats $50
Steering column surround $50
Gear selector surround and boot $40
Center console $40
Climate control unit $30
Rear seat $30
Rear parcel shelf/child restraints/factory speaker grill $30
Indicator switch $20
Wiper switch $20
Hey wondering if you've still got any parts left? I'm needing a Rear Windscreen for my R33, any luck that you've still got that lying about?
Yeah mate still have it you have pm
Still available below! prices negotiable!
HKS Super Drager including high flow CAT back now $250
Series 2 reo $100
16 inch R32 GTST wheels and tyres 90% tread $350
Manual LSD 4:11 tight $180
Driveshafts $180
Stock suspension $80
Side skirts custom $80
Rear windscreen $80
Quarter windows $50
Mirrors $40 each
Tail light left $40
Rear garnish $40
GTST Badges $40
Left Door $30
Right Door $30
Wipers and motors $30 (front motor sold)
OEM Coilpacks $100
S1 engine loom $100
Cross member $80
Radiator $80
Engine mounts $70
Alternator $70
Fuse box lid $20
Seatbelts $80
Ignition barrell and all locks matching key $80
Passenger side window motor $50
Center console $40
Wiper switch $20
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
