BLITZ9100 Posted February 11, 2013 Share Posted February 11, 2013 PM'd Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6746053 Share on other sites More sharing options...
donut_kng Posted February 12, 2013 Author Share Posted February 12, 2013 Sold the following: rear bar boot lid left foggy left headlight boot trim raidus rods front lower control arms SARD FPR centre console Heaps of performance bits still available as well as Complete RB25 Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6747996 Share on other sites More sharing options...
donut_kng Posted February 12, 2013 Author Share Posted February 12, 2013 WOLF V500 Direct plug in ECU for RB25DET R33 - $500, take it away! The current model of this ECU retails at $1,995.80 incl GST: http://wolfmotorspor...3-gtst-plug-in/ This ECU is a direct plug in ecu which plugs into factory harness - no chopping harnesses or piggy backing harnesses, very clean installation capable of producing great results. Inludes laptop plug - great condition, like new, also ran great when installed in the car - removed from parted vehicle which was not smashed or damaged at all Spec attached in pdf. file attached below. Wolf_V500_Specification_Sheet1.pdf Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6748185 Share on other sites More sharing options...
donut_kng Posted February 13, 2013 Author Share Posted February 13, 2013 sold rear brake rotors rear calipers handbrake cable washer bottle rear bar boot lid Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6749745 Share on other sites More sharing options...
Just_Rb Posted February 14, 2013 Share Posted February 14, 2013 hey, how you going with that fuel pump and surge kit, is it still available? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6751177 Share on other sites More sharing options...
donut_kng Posted February 14, 2013 Author Share Posted February 14, 2013 hey, how you going with that fuel pump and surge kit, is it still available? Hey In tank pump still available, surge kit setup is sold. Cheers Many parts still available complete clean R33 series 1 interior and body panels will create list soon Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6751677 Share on other sites More sharing options...
Just_Rb Posted February 15, 2013 Share Posted February 15, 2013 Hey In tank pump still available, surge kit setup is sold. Cheers Many parts still available complete clean R33 series 1 interior and body panels will create list soon Did you find out what kind of pump it is? Also how much? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6753325 Share on other sites More sharing options...
donut_kng Posted February 16, 2013 Author Share Posted February 16, 2013 Not sure yet will let you know. Engine and box sold Tailshaft sold Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6753893 Share on other sites More sharing options...
donut_kng Posted February 18, 2013 Author Share Posted February 18, 2013 Series 2 body parts still available all striaght as. Complete interior still avalable - all prices negotiable. Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6756084 Share on other sites More sharing options...
donut_kng Posted February 21, 2013 Author Share Posted February 21, 2013 Still available below! prices very negotiable!HKS Super Drager CAT back was $500 now $300 Clutch Kit $200 Series 2 front Bar - slight dent on front and pre cut for cooler $150 Series 2 headlight right good condition $300 Series 2 reo $100Blitz 850cc Injectors in stock rail - $45016 inch R32 GTST wheels and tyres 90% tread $450Series 2 Bonnet - straight as - perfect - $40017x7 inch wheels and tyres 80% tread $300Front callipers $270 $100Rear 5 stud hubs $120Manual LSD 4:11 tight $200Driveshafts $180Stock suspension $150 $80Front rotors $50Front 5 stud hubs $50Rear lower control arms $50Side skirts custom $120 $80Front windscreen $100Rear windscreen $80Front guard left $60Front guard right $60Door Rubbers full set $70Rear wing series 2 style but a little taller aftermarket? $50Quarter windows $50Front door windows $50Mirrors $40Tail light left $40Tail light right $40Rear garnish $40GTST Badges $40Left Door $30Right Door $30Wipers and motors $30Misc Manual Conversion bits $200Air con compressor $120OEM Coilpacks $100S1 engine loom $100Cross member $80Power steer rack $80Radiator $80Engine mounts $70Alternator $70Power Steer bottle and hoses $40Radiator overflow bottle $20Fuse box lid $20RB25 Exhaust manifold $50Dash cluster 150xxxkms - worked perfect $120Drivers side window motor $100Jap steering boss kit and AUTOTECHNICA wheel $100Instrument cluster with vents $80Seatbelts $80Ignition barrell and locks $80Drivers side window switch $60S1 Door trims and quarter trims - slight marks $50Passeneger side window motor $50Series 1 Front seats $50Steering column surround $50Gear selector surround and boot $40Center console $40Climate control unit $30Rear seat $30Rear parcel shelf/child restraints/factory speaker grill $30Indicator switch $20Wiper switch $20 Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6760859 Share on other sites More sharing options...
^pilotboy^ Posted February 21, 2013 Share Posted February 21, 2013 interested in the wolf Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6760924 Share on other sites More sharing options...
donut_kng Posted February 22, 2013 Author Share Posted February 22, 2013 Wolf ecu Is now sold Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6762440 Share on other sites More sharing options...
atsillac Posted February 27, 2013 Share Posted February 27, 2013 Hey wondering if you've still got any parts left? I'm needing a Rear Windscreen for my R33, any luck that you've still got that lying about? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6767340 Share on other sites More sharing options...
donut_kng Posted February 27, 2013 Author Share Posted February 27, 2013 Hey wondering if you've still got any parts left? I'm needing a Rear Windscreen for my R33, any luck that you've still got that lying about? Yeah mate still have it you have pm Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6767566 Share on other sites More sharing options...
donut_kng Posted February 28, 2013 Author Share Posted February 28, 2013 Still available below! prices negotiable!HKS Super Drager including high flow CAT back now $250 Series 2 front Bar - slight dent on front and pre cut for cooler $150 Series 2 headlight right good condition $300 Series 2 reo $100Blitz 850cc Injectors in stock rail - $45016 inch R32 GTST wheels and tyres 90% tread $350Rear 5 stud hubs $120Manual LSD 4:11 tight $180Driveshafts $180Stock suspension $80Front 5 stud hubs $50Rear lower control arms $50Side skirts custom $80Front windscreen $100Rear windscreen $80Front guard left $60Front guard right $60Door Rubbers full set $70Rear wing series 2 style but a little taller aftermarket? $50Quarter windows $50Front door windows $50Mirrors $40 eachTail light left $40Tail light right $40Rear garnish $40GTST Badges $40Left Door $30Right Door $30Wipers and motors $30 (front motor sold)Air con compressor $120OEM Coilpacks $100S1 engine loom $100Cross member $80Power steer rack $80Radiator $80Engine mounts $70Alternator $70Power Steer bottle and hoses $40Radiator overflow bottle $20Fuse box lid $20RB25 Exhaust manifold $50Dash cluster 150xxxkms - worked perfect $120Drivers side window motor $100Jap steering boss kit and AUTOTECHNICA wheel $100Seatbelts $80Ignition barrell and all locks matching key $80 S1 Door trims and quarter trims - slight marks $50Passenger side window motor $50Center console $40Climate control unit $30Rear parcel shelf/child restraints/factory speaker grill $30Indicator switch $20Wiper switch $20 Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6769097 Share on other sites More sharing options...
donut_kng Posted March 8, 2013 Author Share Posted March 8, 2013 Bits still available! Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6777266 Share on other sites More sharing options...
Jamie77 Posted March 8, 2013 Share Posted March 8, 2013 This s2 front bar still available ? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6777329 Share on other sites More sharing options...
Jamie77 Posted March 11, 2013 Share Posted March 11, 2013 Still wondering? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6779145 Share on other sites More sharing options...
donut_kng Posted March 18, 2013 Author Share Posted March 18, 2013 sold sorry Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6787841 Share on other sites More sharing options...
YT 1990 Posted March 24, 2013 Share Posted March 24, 2013 Do you still have the child restraints? Link to comment https://www.sau.com.au/forums/topic/419487-wrecking-built-r33-rb25rb20sr20-performance-parts-available-garrett-3071blitzsardboschgfbwolfhybrid/page/2/#findComment-6793462 Share on other sites More sharing options...
