hi all, just wanting some opinions on fitting twin intank e85 pumps to an r32 gtr, has anyone done this? how did you do it? what size lines did you use, jhave you seen people running a bulkhead fitting fitted to the top of the sender or is there another way round this?
thankyou all! :no:
https://www.sau.com.au/forums/topic/419489-twin-pump-intank-setup-for-r32/
I've got twin Nismo pumps in my tank.
Mounted either side of the cradle inside the tank, I sat a pump on each Side of the cradle, than put a large hose clamp around the 2 pumps and the cradle, and tighten them up.
For fuel lines I ran a line off each pump, into a Y section just before the lid of the tank.
For power I ran in 2 extra wires, for the second pump, they both ran on direct power to the battery, (which is in the boot) I have 2 relays 1 for each pump.
So far works perfect, never had any surging issues, even when running the tank low. Like real low, light being on.
The car only on 98 ATM with -5s. The fuel is setup for e85, when I'm home from work next, it's getting the intercooler changed and going for a e85 tune. So time will tell if its enough fuel, but I'm sure there will b heaps.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
