Wiring Problems On A S1 R33 Det
4door_Sleeper
 Share
Hi
Having a run of bad luck. The other day my air conditioning fan belt broke. got caught up in the thermal fan, then jagged the wiring for the Cam Angle Sensor, pulling out the plug and shredding it and the wires nearly as far back as the temp sender.
Anyway, a long walk home, then an expensive tow truck bill, the car is home.
I have sourced a second hand plug with 20cm of wiring still attached, but the wiring colours are different to mine, and there wasn't enough of my original plug left to work out the wiring order.
Could someone please take a picture or report back on the order of the wires.
My original wires are red, green, white and black, and I need to know the correct order in the plug.
The plug is 4 pin, and looking into the plug with the wires out the back and press release button on the top I see this.
(....1...2...3...4.... )
I searched the forums and goggled, but have not found a site that lives the pins in terms of wire colour.
Edited by 4door_Sleeper
Well it's all soldered up, heat shrink on and ........ nothing happens. :verymad:
Car turns over but no sign of life.
Too dark now to do much else - I'll unsolder it in the morning and look for some sign that it has a short (I hope)
Otherwise I may have to call a mobile auto electrician
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
