(honestly I don't think anyone will want it but anyway..)
Got a windscreen for sale, R33 off a GTR. Non-genuine/non-Nissan parts though :P
Looking at around $100 for it. Obviously pickup in Sydney only. It's just a normal windscreen so I don't think I'll need to post a pic hey? FFS all windows looks the same! lol
PM me with offers thanks.
https://www.sau.com.au/forums/topic/41950-r33-windscreen/
The reason i ask is with my insurance i get a free windscreen per year....
What would be difference between the Genuine and non Genuine?
Who sells/installs them? Just a normal windscreen place like windscreens o'brian?
https://www.sau.com.au/forums/topic/41950-r33-windscreen/#findComment-859372
ferni , why would you want to change your w/s if its new , the only thing you may achieve is some scratches on the bodywork when they change it or even water leaks . if i had a good w/s there is no way i would be changed it just because someone else is paying for it
https://www.sau.com.au/forums/topic/41950-r33-windscreen/#findComment-860543
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
