Hi, im a newb with mod plates, never had to get a car mod plated and I dont know what actually needs mod plating -
Quick history is this, car is originally an R33 S2 GTS Auto, car has had following swaps done,
Engine swap to 25DET
Gearbox swap to 5 Speed
coilovers
Slotted rotors
FMIC ( return flow type )
Now im pretty sure the last 3 dont need plates but what about engine and gearbox? do they need plates??? I have been told yes by some and no by others, I have zero history of when the swap was done, previous owner purchased as it is, spark plug failure caused him to have engine rebuilt that's about all I know ..... I have no idea with the legalities of any of this but I want to stay away from the defect notices ( im in QLD if that makes any difference )
https://www.sau.com.au/forums/topic/419511-mod-plates/
engine swap to the same type of engine doesn't need a blue plate - just need to notify qld transport of the change in engine number
engine swap to a different type of engine (eg RB20 to RB25) needs a blue plate
For a 25DE to DET you will need a mod plate of some form. not sure if it will be the 'engine change' code or 'adding a turbo' code you will need though.
When I did a manual conversion on my old skyline I was told by qld transport it doesn't need a mod plate if you use all the parts from a factory manual of the same car.
Can't mod plate coil overs, don't need to mod plate slotted rotors.
FMIC if you haven't cut any body metal to fit it won't need a mod plate. If you have it will need one, and might be difficult to get.
https://www.sau.com.au/forums/topic/419511-mod-plates/#findComment-6743563
Cops/transport can defect you for anything that isnt factory, got mine done at next up performance in rocklea but they get a bloke to come out and sign it off, i got engine,turbo,intercooler,surge tank cost $340
https://www.sau.com.au/forums/topic/419511-mod-plates/#findComment-6746749
  • 4 weeks later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
