Sorry for another actuator thread and I have searched but my problem seems a little different.
I went for a drive yesterday and the drivers doors wouldn't unlock with either my fob or the key in the lock. There is resistance from lock and when I use the fob there are no flashes unless I press the lock button. I ended up going through the boot and opening it using the switch to unlock the but if I use fob or key nothing happens for locking or unlocking regarding the locking mechanism it self. I don't fancy leaving the car unlocked or climbing through the boot each time so hoping for some help/advice.
I'm wondering if I replace the actuator will this solve my problem or is it something else freezing up?
Cheers in advance
Niall
P.S Passengers door doesn't move either but never has(actuator gone)
https://www.sau.com.au/forums/topic/419536-actuator-gone-or-something-else/
Sounds strange, but i have been researching for weeks trying to find a half decent video/images guide on how to replace the door lock actuator as i have a new one sitting at home but i can't manage to get my arms into the tiny space to work with it.. and i don't fancy the idea of removing the window.
i seem to have a thing for saying "id be checking the fuses" latey.... but yeah thats what i'd do. sounds like the locking system could have no power, turning the key would feel heavy because its not being electrically assisted.... pressing the lock botton on the window switch panel should also have no effect (but thats assuming its not an independant circuit)
it could well be the actuator tho
Hmmm well the key and fob both started working again this afternoon and then all of a sudden stopped. The lights now seem to work when I use the fob and sounds like the lock is trying to move but nothing happens along with when I use the key. I'll check all the fuses tomorrow and also try and remove the door panel to see. I can't seem to find the diy on how to replace the oem actuator.
i took the entire trim off when i replace my window motor, the door lock is located in a stupidly tight place. Right up in the corner, it's not an easy job i haven't tried it yet but it looks tricky as hell.. that's why people opt to do the $5 fix which you can find the DIY on g35driver.com
Yeah I've looked at the $5 fix not sure whether to go for it or not, I'm going to have to get my hands on the packs if I do but I'd rather replace the oem part to be honest as long as I could find the DIY with pictures.
I'll probably try replace it next weekend with a mate, if you find a DIY please let me know mate. I have looked over the internet a fair bit though so unless it's been put up recently i don't think you'll have much luck :/
gut the door... so glass out, wind reg out, guide rails out,
already said this 3-4 times now.. if you are not confident in doing it pay someone to do so :)
There isn't anyone worth paying in Mackay. Think that that's the problem.
Ended up doing the actuator fix tonight. Was a pain in the ass but seems to be working quite well now. Been wanting to do it for over 2 years now since i bought the V. Couldnt bring myself to drill holes and cut off pieces of the lock.
Bought a spare interor door handle just in case I screwed up.
Edited by jjjones
i did it over the span of 3 days.
1st day i taped the central locking wires behind the speaker (20mins).
2nd day i created the bracket and mounted the actuator on it (30mins).
3rd day i drilled holes in the lock and door card and mounted everything (2 hours).
Its actually a very easy fix to install. The only thing that worried me was making sure i was drilling holes in the right spot to have it all aligned properly.
I would suggest buying a spare interior door handle. The fix requires you to snap off a tab in the handle which means if you decide not to go ahead with the fix and want everything back to the way it was, the lock cable has a high possibility to fall out.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
