Sorry for another actuator thread and I have searched but my problem seems a little different.
I went for a drive yesterday and the drivers doors wouldn't unlock with either my fob or the key in the lock. There is resistance from lock and when I use the fob there are no flashes unless I press the lock button. I ended up going through the boot and opening it using the switch to unlock the but if I use fob or key nothing happens for locking or unlocking regarding the locking mechanism it self. I don't fancy leaving the car unlocked or climbing through the boot each time so hoping for some help/advice.
I'm wondering if I replace the actuator will this solve my problem or is it something else freezing up?
Cheers in advance
Niall
P.S Passengers door doesn't move either but never has(actuator gone)
https://www.sau.com.au/forums/topic/419536-actuator-gone-or-something-else/
Sounds strange, but i have been researching for weeks trying to find a half decent video/images guide on how to replace the door lock actuator as i have a new one sitting at home but i can't manage to get my arms into the tiny space to work with it.. and i don't fancy the idea of removing the window.
i seem to have a thing for saying "id be checking the fuses" latey.... but yeah thats what i'd do. sounds like the locking system could have no power, turning the key would feel heavy because its not being electrically assisted.... pressing the lock botton on the window switch panel should also have no effect (but thats assuming its not an independant circuit)
it could well be the actuator tho
Hmmm well the key and fob both started working again this afternoon and then all of a sudden stopped. The lights now seem to work when I use the fob and sounds like the lock is trying to move but nothing happens along with when I use the key. I'll check all the fuses tomorrow and also try and remove the door panel to see. I can't seem to find the diy on how to replace the oem actuator.
i took the entire trim off when i replace my window motor, the door lock is located in a stupidly tight place. Right up in the corner, it's not an easy job i haven't tried it yet but it looks tricky as hell.. that's why people opt to do the $5 fix which you can find the DIY on g35driver.com
Yeah I've looked at the $5 fix not sure whether to go for it or not, I'm going to have to get my hands on the packs if I do but I'd rather replace the oem part to be honest as long as I could find the DIY with pictures.
I'll probably try replace it next weekend with a mate, if you find a DIY please let me know mate. I have looked over the internet a fair bit though so unless it's been put up recently i don't think you'll have much luck :/
gut the door... so glass out, wind reg out, guide rails out,
already said this 3-4 times now.. if you are not confident in doing it pay someone to do so :)
There isn't anyone worth paying in Mackay. Think that that's the problem.
Ended up doing the actuator fix tonight. Was a pain in the ass but seems to be working quite well now. Been wanting to do it for over 2 years now since i bought the V. Couldnt bring myself to drill holes and cut off pieces of the lock.
Bought a spare interor door handle just in case I screwed up.
Edited by jjjones
i did it over the span of 3 days.
1st day i taped the central locking wires behind the speaker (20mins).
2nd day i created the bracket and mounted the actuator on it (30mins).
3rd day i drilled holes in the lock and door card and mounted everything (2 hours).
Its actually a very easy fix to install. The only thing that worried me was making sure i was drilling holes in the right spot to have it all aligned properly.
I would suggest buying a spare interior door handle. The fix requires you to snap off a tab in the handle which means if you decide not to go ahead with the fix and want everything back to the way it was, the lock cable has a high possibility to fall out.
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
