Sorry for another actuator thread and I have searched but my problem seems a little different.
I went for a drive yesterday and the drivers doors wouldn't unlock with either my fob or the key in the lock. There is resistance from lock and when I use the fob there are no flashes unless I press the lock button. I ended up going through the boot and opening it using the switch to unlock the but if I use fob or key nothing happens for locking or unlocking regarding the locking mechanism it self. I don't fancy leaving the car unlocked or climbing through the boot each time so hoping for some help/advice.
I'm wondering if I replace the actuator will this solve my problem or is it something else freezing up?
Cheers in advance
Niall
P.S Passengers door doesn't move either but never has(actuator gone)
https://www.sau.com.au/forums/topic/419536-actuator-gone-or-something-else/
Sounds strange, but i have been researching for weeks trying to find a half decent video/images guide on how to replace the door lock actuator as i have a new one sitting at home but i can't manage to get my arms into the tiny space to work with it.. and i don't fancy the idea of removing the window.
i seem to have a thing for saying "id be checking the fuses" latey.... but yeah thats what i'd do. sounds like the locking system could have no power, turning the key would feel heavy because its not being electrically assisted.... pressing the lock botton on the window switch panel should also have no effect (but thats assuming its not an independant circuit)
it could well be the actuator tho
Hmmm well the key and fob both started working again this afternoon and then all of a sudden stopped. The lights now seem to work when I use the fob and sounds like the lock is trying to move but nothing happens along with when I use the key. I'll check all the fuses tomorrow and also try and remove the door panel to see. I can't seem to find the diy on how to replace the oem actuator.
i took the entire trim off when i replace my window motor, the door lock is located in a stupidly tight place. Right up in the corner, it's not an easy job i haven't tried it yet but it looks tricky as hell.. that's why people opt to do the $5 fix which you can find the DIY on g35driver.com
Yeah I've looked at the $5 fix not sure whether to go for it or not, I'm going to have to get my hands on the packs if I do but I'd rather replace the oem part to be honest as long as I could find the DIY with pictures.
I'll probably try replace it next weekend with a mate, if you find a DIY please let me know mate. I have looked over the internet a fair bit though so unless it's been put up recently i don't think you'll have much luck :/
gut the door... so glass out, wind reg out, guide rails out,
already said this 3-4 times now.. if you are not confident in doing it pay someone to do so :)
There isn't anyone worth paying in Mackay. Think that that's the problem.
Ended up doing the actuator fix tonight. Was a pain in the ass but seems to be working quite well now. Been wanting to do it for over 2 years now since i bought the V. Couldnt bring myself to drill holes and cut off pieces of the lock.
Bought a spare interor door handle just in case I screwed up.
Edited by jjjones
i did it over the span of 3 days.
1st day i taped the central locking wires behind the speaker (20mins).
2nd day i created the bracket and mounted the actuator on it (30mins).
3rd day i drilled holes in the lock and door card and mounted everything (2 hours).
Its actually a very easy fix to install. The only thing that worried me was making sure i was drilling holes in the right spot to have it all aligned properly.
I would suggest buying a spare interior door handle. The fix requires you to snap off a tab in the handle which means if you decide not to go ahead with the fix and want everything back to the way it was, the lock cable has a high possibility to fall out.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
