Hey guys,
I’ve heard of these tuners on the net that you apparently can send in the list of mods you have done and they tune it as best as they can. Then you go get a dyno run and check your mixtures and if they are not 100% you can send it back and they will adjust it for free.
The reason for me looking into this is its $200 and I’m trying to do up my r33 gtst as cheap as i can as i have a young family and I don’t have the luxury to spend thousands on my toy so its a slow cheap project.
I’m not planning for it to be to crazy I’m hoping to have a r34 side mount water cooled and 3 inch full system fuel pump standard air box with k&n panel
Has anyone had experience with these internet tuners what’s everyone opinion?
https://www.sau.com.au/forums/topic/419571-internet-tune/
$200 fora R33... Sounds very wrong.
As above, if budget - 10psi is fine (12 can trip it out).
Nothing will beat a proper tune and 'mailorder' tunes will not be much better than a stock ECU as you have to be so conservative.
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6743266
Normal tune $600-1500 depending on workshop.
Tunable ECU is between the same $500-4000 depending on brand.
Decent power depends on what you think is decent and again how much you can budget into it.
Reliable power and low budget do not mix at all sorry to say
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744438
ok so if i was to do
full 3 inch system
fuel pump
k&n pannel
water coolded r34 intercooler
10 psi
maybe a tune later on down the track
that would be ok power? there is nothing else i could do on the cheap
and for those mods what kind of fuel pump do i get? and would you bother with injectors?
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744577
With a budget build I wouldn't bother with injectors because they will require a tune
The stuff you have listed will be fine without a tune as long as you make sure it's 10psi and no more.
With a tune it would make a huge difference though.
I went a walbro 255 as they are easy to fit and no expensive. Got mine for $200 including the install
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6744622
full 3 inch system
fuel pump
k&n pannel
10 psi
34 coolers are water to air?
at the power levels youve hinted to being able to afford right now, keep the standard cooler.
again, dont worry about fuel pump either.
just get a boost controller(electronic) and run 10psi, the factory systems should have enough leway in them.
start saving, and do a nice group of mods when you can afford it.
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6745377
Hey guys,
Hey mate
Best thing to do is contact Toshi
He is on SAU and is fantastic
Costs about $400
He will send you replacement ECU that he has socketed and rechipped for your mods
Very very accurate tune
He has done many tuned chips for so many different configurations of mods
My car is an R33 GTST running 12PSI and has FMIC and 3" with man boost control
I beat most V8's out there and air fuel ratios are spot on
Also great MPG.
If you need any help contacting him just ask
And for all you doubters out there I say come for a drive of my car (or a race!!)
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6746062
Hey mate
Costs about $400
Also great MPG.
Good read, would lol again
https://www.sau.com.au/forums/topic/419571-internet-tune/#findComment-6747124
