yeah wow i mean even if they are "hand made" cant see the sense in paying 2k for a manifold unless you have more money then sense... as for the trust the day will come when one of us buy it after old mate has road the 32 off wont be long and as i had 8k flashed in my face all i seen was manual conversion for the laurel and more haha
hard one of them nights tonight everything going great manifold almost back on nek minute stud randomly strips out of the block :( arhhh thank god for helicoils really want it back on before the weekend so i can get stuck in to other things and take it for a spin ;)
CARS GOING AGAIN manifolds back on and all going not leaking from manifold any more but is a small leak coming from where the dump pipe bolts to the turbo as one of the bolts are stripped will fix that should be easy fix hope so anyway then would like to take it to have it put on the sniffer just to make sure everything is ok with the tune and that as im not sure whats been done look it for a good drive last night and filled it up and drove 184km on highway and i had just over quarter of a tank left!! :woot: so it really really loves fule its done smell to rich and its not all black up the back of the car i believe it has something to do with the auto box and it slipping as its getting worse wont even go skids :( so sad but all that will change as soon as i get the manual in it cant wait to have it done and few little issues left and should be running good only really need to sort out the hand break and cable now...
all my goodies showed up today thanks to phatlavish for everything now have
-rb25 gearbox
-crossmember C (fit right in no mods needed tested this on frenchie1001's laurel the other night)
-excedy button clutch
-flywheel
-break and clutch pedals
-manual dash cluster
-laurel manual center console
-manual shifter
-all bolts for gearbox and everything
-r33 tailshaft
-manual wiring loom
-sandwitch plate
parts still needed:
-clutch slave cylinder
-clutch master cylinder
-clutch line
-r32/a31 manual handbreak
-a31/c33 handbreak cable
-mod tailshaft (going to try front 33 back manual laurel shaft
-gearstick dash surround
hope i haven't forgotten anything
havent done anything else to mine and probably wont this week been working every night this week on zacs laurel (frenchie1001) and after almost 12 months of work building it will (finger crossed) start tomorrow been a great build and learnt heaps be awesome to see it back on the track!!!
no i haven't found a full hand break cable i have the start of it and im hoping it will be able to hook up in to Y section just behind the box but im sure a31 ceffys are the same im gonna try and find one of them if it wont fit as is
well today i actually worked on my own laurel for a change pulled the manifold and everything back off and to find the new manifold is warped really pissed off about this as it was brand new trying to decide on what to do weather to get another one the same or try something different but im not spending $1200 on a 6 boost cant see the sense in that and i all so have bad heat problems wiring melting around the strut tower oil drain line off the turbo has melted through and the silicon bend off the turbo must of been touching as well and has done the same :( so will have bend welded to turbo and the oil drain made longer so it clears the manifold and try to move the wiring on the gearbox conversion side ive recived the the gktech clutch line very fast postage and after being stuffed around something shocking by kudos motorsports with the clutch master and slave told them dont bother after waiting weeks and weeks ive just brought a slave and master of the same guy i got the gearbox and the other parts off he has been a great help and ive found a company in NZ that can convert my electronic speedo to a cable so i can use the 25 box in the laurel so alot going on but im in no rush....
post-93126-0-42192600-1364115273_thumb.j
post-93126-0-60474500-1364115362_thumb.j
post-93126-0-21024000-1364115427_thumb.j
yeah i have noticed haha..
oh really you've done it i wasn't sure on it i would like to do it myself if its easy what speedo sender did you use to convert it with?
Follow this guide here, it's all in there
It's a d21 navara speedo sender they even have the part number at the start of the tutorial for the sender. It was like max 40 bucks for the sender and you reuse your r33 gearboxes speedo cog or you can order a new one I you don't have one/it's f**ked
http://www.jdmlegion.com/KnowledgeBase/Engine%20and%20gearbox%20conversions/Making-a-mechanical-speedo-sender-for-the-RB25-gearbox-f0271b89-cd6e-425d-bc0a-ee62f51dfaa7
well over the ester had a awesome day at the Tasmania drift practice day at symmons plains even if i wasn't driving and and done a little to my car pulled out all the left over aircon ie pump and lines ive started on my conversion as well removed the auto shifter foot break and auto break pedal mounted the clutch pedal and clutch master and the clutch line having trouble getting the actual pin as its in the worst spot and hanging upside down in your car is horrible and with the manifold ive the flange of the manifold in 3 spots (pics to come) as ive been told it can bring the manifold back in to shape and it has so im just gonna give it ago and bolt it up but wont know till the conversion and everything is done but hopefully next weekend can get the auto box out and look at putting the manual in :) cant wait
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
