should be making over 300 on that boost with that turbo so deffs something wrong there
yeah as i said i have problems with ecu sensors jumping all over the place so it is only a half tune and im not really going for max power
  • 3 weeks later...
need to think/find a new muffler/pipes for the back as the cannon thats on there sucks ass and im thinking twin tip but not sure even another cannon that looks better and sounds better would do please discuss!!!
spent saturday down hobart helping frenchie out with his bus at the round 3 drift day was a good day besides small miss hap that ended the day but the day gave me a boost to do a bit of work on mine today as im still waiting for wiring to get down before it can go back to have the tune finished :down: so just done some fiddly things started fixing a dicky power window and after taking the door trim off found the car had the intrusion bar cut out and a large rhs frame welded in to the door like a heavy duty crash bar or something super strange and have no idea why its been done as the doors have had no repairs or new skin welded to it
other news brought first pair of wheels vskf in 17x9 +18 and have another pair soon 18x9.5 +18
hks oil cooler and oil filter relocation on the way a stainless twin 3inch pipe being made
damo come done last of the wiring on saturday air temp sensor in earth for the ecu fixed power steering fixed heap of wires cleaned up and neatened and is going back in to have the tune finalised this week and some actually good power figures will be up soon the kfs and going in tomorrow to have tyres changed over and try to get them back on and ply with camber and what not to make them fit ready for tune
well not the best news.. after having the wiring issues fixed on the ecu what we thought was a bad earth that was making the sensors (tps,water temp) gitter and making the motor run super rich i then took the laurel back to the tuner (boost automotive) car had to stay there for a day or 2 as he had to tune the cold start and finalise everything else got a text the next morning and was told the car is still not right and is still all over the place as you can imagine i wasn't after stuffing around with the car for so long and and this ecu so that night wiring mate (DJRIFT) went back through the wiring trying to find a bad earth or bad anything started to think as the ems runs off the ome ecu some of the sensors may of been doubled up and that was making things gitter and go all over the place fixed a few wires sent it back there the next morning still no go better but still no go so this weekend we went back over everything with a borrowed laptop to see if we could get it to work we really went through everything tested every wire and every ground nothing we could do seemed to fix the gitter :( we pull the ems out to check the ecu its self we found what may be sign of water damage and to the computer its self so in the end we have out it down to that the ems ecu has shit its self pretty much from water damage or just from age or bad luck and have now been set back more with having to buy a new computer and im not going to put a cheap half ass computer in it im looking at a haltech platinum pro unsure just sad on the hole car at the moment waaaaa :down:
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
