Given the age of the car, the existing paint would not be exactly what it was when new so it may actually be correct.
Did you get the can made up or was it off the shelf? I tried Autobarn as they can make up cans from paintcodes but the colour they came up with was not right.
Went to an actual Automotive Paint shop, and they got it straight away.
Thanks mate, will try that. im in ACT aswell. which auto paint shop did you try?
  • 1 year later...
I've got a '96 Skyline with the Cloud White QM1 paint. Just did a small touch up on the back bumper. Used Holts Dupli Color Polar White DSD42 from Autobarn. Looks like a very good match.
Holts Dupli Color paint codes.
http://www.saauto.com.au/userfiles/file/Catalogues/Duplicolor/Dupli-Color%20Guide%202011.pdf
According to the Holts paint guide there are 4 Nissan QM1 paints. Polar White DSD42, Alabaster White DSF76, Alabaster White Var R DST45 and another Alabaster White DST52. I'd say the Polar White is the whitest and the Alabaster Whites have a bit more cream in them.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
