I would also be down for a set for sure, do speedflow do black fittings, as the blue and red anodized look nice but easy for the cops to pick up on, i would rather keep everything stealth if possible! I checked with Stao and yes the highflows use the same size fittings as the standard turbo so myself and Miguelone would need exactly the same fittings as yourself.
Yes all fittings even the braided lines are available in black, however prices may vary because its a different 'series'.
Also, i should have sprayed my block black while it was out, damn yours looks sexy with those cam covers!
Yeah its quite easy to do whilst the engine is out hey :P
In any case you can still do you cam covers as they are not that much effort to remove when the engine is still on the car
Just an update
Motor was put in last weekend and she's been running since!
704814-663138193700543-1337119272-o-6631
Car is currently at the mechanics undergoing a RWC:
326907-663138087033887-1372648726-o-6631
Once rego'd will rack on 1,000km's.
Bump it to 23 psi then dyno @ Chequered Tunning!
Didn't get to take that many pics from the install weekend but here is a few:
Getting the gasket on before the manifold goes on. I will say it was a bitch to get some of the nuts on for the manifold
175083-663140873700275-228167280-o-66314
1010564_663140873700275_228167280_n.jpg?
NGK bcp7res gapped to 0.8mm with Genuine nissan coil packs
969983_663140837033612_657369171_n.jpg?o
Car been sitting outside so long it has plants growing in it:
375573_663140863700276_1043087673_n.jpg?
Getting the clutch on:
1015059-663141030366926-1908397285-o-663
1015537-663140987033597-1025357822-o-663
1015563-663140963700266-378721262-o-6631
One of the benefits of a rebuild. Getting stickers :/
1008975-663141110366918-2038086741-o-663
Initial impressions when driving the car, I was afraid that the clutch would be heavy as fu*rk. But it is surprising light. Even lighter than my old clutch which was an Xtreme organic heavy duty clutch that only handles ~260kws or there abouts. And this handles 380rwkw!
Oh wow! Its all happening!
Can't wait for the dyno results, and being able to thrash her again!
Let me know when it's getting tuned mate, I want to drop down for a look. (and a kebab, that shop next door has great food.) :P
When is Trent back from the US?
I let you know! Stao from Hypergear is also coming down to watch as he is keen to see what the max a ss2 internal gate on 98 will do.
Trent just got back from the US a few days ago. Workshop is back open!
Will also need to pay Scotty Customs a visit after to get a turbo bracket made :P
Thanks.
I saw the shop was open Today as I drove past, have you booked it in yet? Must be quite a line of cars for him to catch up on.
No problem, drop in anytime and explain what you want made. I have some good ideas on it already.
Been following this from the beginning and its a great build.
Also what clutch have you got? Looks similar to the NPC carbotic.
It's an NPC. I've been told its a Heavy Duty cushioned Button one. Also has the billet lightweight flywheel. Drive ability I didnt have any issues with
Thanks.
Not booked in yet. Have a feeling there will be a few things ill need to fix up for the RWC.
But yeah always need to book a week or so in advance with Trent!
  • 4 weeks later...
So finally the car is back on the road and is registered!
Bit of a delay due to:
Roadworthy:
Getting rims that didnt fit
Getting a stock cat from a Stagea that didn't fit
New radiator blown
Heater core playing up
And then in a dispute with Vicroads on whether I needed a VIV, so ended up looking up the legislation which said I didn't need one
So time to rack up some 1000kms and then a tune with Trent when he gets back from O/S
Then once that is done this project aint over!
Going for wider front + rear guards to fit wider rims and tyres. So watch this space :D
Roadworthy:
New radiator blown
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
