cool build, great to see some nicely built 25GTt's.
definitely invest in some good tyres, coilovers and arms/bushes,will make a bigger difference to laptimes than a bit more power (though obviously you want to sort the restriction out first..)
ive got cusco arms, great build quality and got a perfect alignment with them, car feels great on the track.http://www.cusco.co.jp/en/catalog/pdf_catalogue_suspension_parts.html
nagisa auto also do a bunch of arms for R34 25GTt http://www.nagisa-auto.com/products.html
i'd order throught jessestreeter, should be able to get the stuff for a reasonable price for made-in-japan quality. my 2c.
Cheers :thumbsup:
New suspension setup & a 1.5way diff are definitely on the cards next!
I have some Hankook RS-3 ready to go on which should be good
Cheers for links! It will be helpful once I shop around for parts :)
mate great build going on there. i have had a lot of the same sort of modding ideas as you have done already.. good to see that all of it is working out for you which helps me out a lot also.
great inspiration mate good up the great work
Thanks Jake
Yeah its all slowly starting to come together
Theres still quite a long list of things that I still want to do. It really never stops :/
Quick update:
Just got a few pics from Vu @ DT Panels. Shell is going in for paint tonight, and then assembly tomorrow
1472955_10152052600385937_1296586892_n.j
1459245_10152052600645937_1309428566_n.j
1454960_10152052600770937_1023195141_n.j
1466095_10152052600820937_884529813_n.jp
1441228_10152052600880937_1195689344_n.j
On 12/4/2013 at 5:14 PM, Miguelone said:
What colour did you end up going with?
Ended up going the dark metallic grey from a Subaru Brz.
Additional pics I took today
Hard to tell on the camera, will look at lot better once out in the sunlight:
Base Coat:
Final coat:
1398139-764969923517369-1390868036-o-764
1400460-764969916850703-2136217733-o-764
1402900-764969843517377-96613856-o-76496
thats a really nice colour.
+1 to endless list of things to do on car. But then again, if you ran out it would be less exciting and interesting
Ahh Leroy you and I know that feel
Also
Live updates from Vu @ DT Panels. Great service :D
1471105_10152054579075937_835909422_n.jp
DT Panels had to custom cut the side skirts from the kit as they were made to fit the GTT guards from the old kit. Final result! Good result! and saves me time and money to find impossible GTR side skirts!
1453523_10152054587305937_818755292_n.jp
1468817_10152054603540937_1278311278_n.j
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
