cool build, great to see some nicely built 25GTt's.
definitely invest in some good tyres, coilovers and arms/bushes,will make a bigger difference to laptimes than a bit more power (though obviously you want to sort the restriction out first..)
ive got cusco arms, great build quality and got a perfect alignment with them, car feels great on the track.http://www.cusco.co.jp/en/catalog/pdf_catalogue_suspension_parts.html
nagisa auto also do a bunch of arms for R34 25GTt http://www.nagisa-auto.com/products.html
i'd order throught jessestreeter, should be able to get the stuff for a reasonable price for made-in-japan quality. my 2c.
Cheers :thumbsup:
New suspension setup & a 1.5way diff are definitely on the cards next!
I have some Hankook RS-3 ready to go on which should be good
Cheers for links! It will be helpful once I shop around for parts :)
mate great build going on there. i have had a lot of the same sort of modding ideas as you have done already.. good to see that all of it is working out for you which helps me out a lot also.
great inspiration mate good up the great work
Thanks Jake
Yeah its all slowly starting to come together
Theres still quite a long list of things that I still want to do. It really never stops :/
Quick update:
Just got a few pics from Vu @ DT Panels. Shell is going in for paint tonight, and then assembly tomorrow
1472955_10152052600385937_1296586892_n.j
1459245_10152052600645937_1309428566_n.j
1454960_10152052600770937_1023195141_n.j
1466095_10152052600820937_884529813_n.jp
1441228_10152052600880937_1195689344_n.j
On 12/4/2013 at 5:14 PM, Miguelone said:
What colour did you end up going with?
Ended up going the dark metallic grey from a Subaru Brz.
Additional pics I took today
Hard to tell on the camera, will look at lot better once out in the sunlight:
Base Coat:
Final coat:
1398139-764969923517369-1390868036-o-764
1400460-764969916850703-2136217733-o-764
1402900-764969843517377-96613856-o-76496
thats a really nice colour.
+1 to endless list of things to do on car. But then again, if you ran out it would be less exciting and interesting
Ahh Leroy you and I know that feel
Also
Live updates from Vu @ DT Panels. Great service :D
1471105_10152054579075937_835909422_n.jp
DT Panels had to custom cut the side skirts from the kit as they were made to fit the GTT guards from the old kit. Final result! Good result! and saves me time and money to find impossible GTR side skirts!
1453523_10152054587305937_818755292_n.jp
1468817_10152054603540937_1278311278_n.j
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
