So much mirin Toby
Dark rims suit it I reckon!
Yeah dark rims are good
At the moment the current rims aren't wide enough
And I can't fit spacers at the moment even up to 25mm as the rim hub still hits the old studs
hot dam that paint is gorgeous, it just gets better and better
Thanks scmate!
shiiiieeet can't wait to see in person
Soon Leroy! Soon!
Down at OTR to fit a set of 265/40/18 Hankook Rs3 tyres
Big range of rims and friendly bunch of guys.
1500786-767654359915592-1630476257-o-767
Tried some Te37 SL's 18 x 10.5 + 15 for fun. They have an Advan 050 295 tyre on them i think
1486051-767654363248925-3673169-o-767654
1502900-767654343248927-375397347-o-7676
1471263_767654363248925_3673169_n.jpg?oh
1466217_767654343248927_375397347_n.jpg?
Hankooks on
1501024-767654389915589-2129078233-o-767
Front tyres are scrubbing the top bit of the suspension so I need to go either a 35 profile tyre or somehow fix the problem
On 12/9/2013 at 6:27 PM, owen1r said:
Hnnng those TE37s are hot, awesome colour combo maybe you should treat yourself for christmas?
Ahh thanks mate. Spending that much on rims is out of my price range at the moment. I don't mind TE37's but prefer them in 19's with the dish!
So this is what happens when you run too chunky of a tyre. Suspension arm/knuckle is touche the tyre. Might need to angle grind it down for more clearance
Also I did play around with the idea of white writing on the tyres after seeing one on a hankook race car. But decided not to go ahead with it haha
1167417_768541539826874_1796915530_o.jpg\
1167417-768541539826874-1796915530-o-768
Ah, I see now.
That's the camber arm, not the knuckle. Just cut the arm down.
If you really want, buy a offset bush and offset the arm higher. It will clear easy that way.
Oh i forgot to say that pic is with a 8mm spacer that I was trialing
Oh thanks. I have no idea about suspension bits lol
Might look into the offset bush if it is also a cheap solution
Are there other bits I may as well change at the same time if I change the bush?
Suspension is stock except for coilovers, so would like to do a few things to improve the handling before the next track day
I know I probably need front and rear adjustable camber arms for more negative camber
On 12/11/2013 at 6:48 PM, Count Grantleyish said:
Isn't 40 profile bit too tall for Skylines? Most run 35 profile.
Yes it is a bit tall haha
Test fit of XD9's 18x10 + 18 265 Achilles tyre. Plenty of clearance
I don't mind Xd9s...
902351-768766373137724-320856539-o-76876
10750324-958603354154024-226993447194029
1401516-958603400820686-7929943015456419
  • Like 2
On 12/11/2013 at 7:37 PM, Count Grantleyish said:
How many wheels have you trial fitted so far?
Hehe just borrowing a friends wheel for now till i fix the issue
If anyone has any Ce28ns I can trial fit...
This is the clearance I have with the Xd9's 265/35 tyre combo
1000117-768792159801812-1283234871-n-768
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
