No need for a pod mate, you will only go backwards. simply cut a few holes on the side of the airbox if you think the snorkel is restricting flow. I have seen nearly 500kw through a cotton panel element.
Braided hoses won't help much, they are only rated to 200 degrees anyway. Bring it around again sometime and we can try and run new rubber hoses over the top of the engine. Or when we do the oil cooler perhaps.
Moh, you are the bitch. :P
Update:
Car issue all sorted
Ended up being a faulty CAS
22 psi down to 18 psi, conservative tune to make sure it is all ok.
Then will be coming back with 2-3 degrees more timing (~20rwkw) and up to 6 psi boost
Top line no airbox
2nd line airbox restriction
11915445-1136794226334935-80194056083257
  • Like 1
30kw gain from not having the airbox lid is interesting, shame we didn't run it up with the lid on and no filter though.
Yes will have to book my car again in the future to modify that airbox :/
holy shit mother f**ker yoda and shit.
you got the 350 you wanted on 98, and then add some for E85. (this is on E85 yeah?)
Yeah tune is on e85
Trent said its going to go over 400rwkw easily once we bump up the timing again and boost
But yeah don't need that much power! Happy with my airbox limited 350rwkw for now lol
Haven't even had a chance to boot it yet, wonder if I will have traction....
Interested about the airbox issue my tuner told me same of being held back some kws due to the airbox. But I've also seen people proving that there are no gains with pods.
Depends at what power level I spose
Im sure at 280rwkw difference would be neglible but once you get up in power it makes power harder to get rather than a brick wall restriction
  • 2 months later...
  • 3 weeks later...
Updates?
Sorry no real updates, have been overseas and taken a step back from working on the car
I think its time to stop spending money on cars lol
In saying that hit a rock in the middle of the freeway that split my lower lip.
So that will get fixed with the insurer along with fixing the whole front bumper, then when I get money a set of D9R's then i think im set :)
what body kit is that mate? looks crazy
Just a Ztune kit mate :)
I was following your thread really closely up until/before you got the kit (and it was still white haha)
Ermagersh you have come a long way man, absolutely balls to wall in terms of the build. Hoping to follow a similar path when I get off p's; in terms of the GTR kit.
PS
I looked up JDL they really don't ship to AUS :'(
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
