I was following your thread really closely up until/before you got the kit (and it was still white haha)
Ermagersh you have come a long way man, absolutely balls to wall in terms of the build. Hoping to follow a similar path when I get off p's; in terms of the GTR kit.
PS
I looked up JDL they really don't ship to AUS :'(
Yup JDL don't ship internationally. But Mad Motors Uk will ship the kit cheap for you :)
so. when are you getting 22s?
When you give me the monies
  • 5 months later...
On 11/1/2014 at 4:51 PM, timmy_89 said:
Holy moly they look big.
For the rest of us, what size are the tyres? :P
Any more pics, maybe some from the front/rear to see how far they stick out lol
1401516_958603400820686_7929943015456419
10708688_958603417487351_657423757586466
10636310_958603330820693_905249546272667
1464647_958603354154024_2269934471940297
10665803_958603370820689_121886134063586
10415726_958603400820686_792994301545641
10689868_958603417487351_657423757586466
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
