1 hour ago, blah_blah said:
Small update
So a few things. Need to fix the rear camber so ordered hard race rear camber arms.
Also rear end bearings were gone so apparently it is easier to order a full HICAS delete kit:
Over the next month will also do a custom cooler piping job and custom airpod box.
May also do Sandown this month but not sure yet
Nice kit! Something to add to the shopping list perhaps is rear traction arms, they'll help counter bump steer in a lowered setup. Here's some more info from when I was looking into that: https://www.sau.com.au/forums/topic/448509-wheel-alignment-question-car-feeling-more-skittish/?do=findComment&comment=7570413
Re Sandown, I'm pretty keen on the Tempered session on Australia Day, might see you there :)
Thanks! Good to know re traction arms! trying to keep mods minimal and concentrate on seat time and a reliable car from here tho.
Looks like im out for Sandown, but if your in let me know and i might pop by
On 1/10/2017 at 10:13 AM, Leroy Peterson said:
You still got HICAS? That shit should be illegal.
Do broadford in March with me. (If I'm not flat out with work)
Hrmm i only just get back from Murica in March. My car wont really suit Broadford lol
  • Like 1
12 hours ago, blah_blah said:
... trying to keep mods minimal and concentrate on seat time and a reliable car from here tho. ...
Smart plan! I'm hoping to do the same :)
I have signed up for Sandown on the 26th, fingers crossed all of last year's issues are fully sorted. If you end up dropping by look for the silver 34 sedan with black wheels :)
On 1/9/2017 at 7:55 PM, blah_blah said:
Small update
15873030_1547821361898884_10733021024492
15873272_1547821401898880_30811198885244
15941199_1547821385232215_89167324168121
Awesome thread! Car looks brilliant.
Where did you order your hardrace parts from? I can't seem to find many sellers these days now
Will do!
Got my hardrace parts via Topstage :)
  • 4 months later...
ZZzzz not sure why my fb links are always broken.
Anyway just a small update doing a xenon projector retrofit atm.
Purchases some 2nd hand lights
18767390_1717804664900552_33819629814147
1st time baking in oven not great lol
18814235_1717804721567213_37423389454635
2nd time much better:
18835502_1717811568233195_61118913565889
Xennon kit has come through:
18920233_1717812311566454_36114802786519
18813545_1717804618233890_63794632662224
End product in a few weeks something like this without the red:
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
