So much mirin Toby
Dark rims suit it I reckon!
Yeah dark rims are good
At the moment the current rims aren't wide enough
And I can't fit spacers at the moment even up to 25mm as the rim hub still hits the old studs
hot dam that paint is gorgeous, it just gets better and better
Thanks scmate!
shiiiieeet can't wait to see in person
Soon Leroy! Soon!
Down at OTR to fit a set of 265/40/18 Hankook Rs3 tyres
Big range of rims and friendly bunch of guys.
1500786-767654359915592-1630476257-o-767
Tried some Te37 SL's 18 x 10.5 + 15 for fun. They have an Advan 050 295 tyre on them i think
1486051-767654363248925-3673169-o-767654
1502900-767654343248927-375397347-o-7676
1471263_767654363248925_3673169_n.jpg?oh
1466217_767654343248927_375397347_n.jpg?
Hankooks on
1501024-767654389915589-2129078233-o-767
Front tyres are scrubbing the top bit of the suspension so I need to go either a 35 profile tyre or somehow fix the problem
On 12/9/2013 at 6:27 PM, owen1r said:
Hnnng those TE37s are hot, awesome colour combo maybe you should treat yourself for christmas?
Ahh thanks mate. Spending that much on rims is out of my price range at the moment. I don't mind TE37's but prefer them in 19's with the dish!
So this is what happens when you run too chunky of a tyre. Suspension arm/knuckle is touche the tyre. Might need to angle grind it down for more clearance
Also I did play around with the idea of white writing on the tyres after seeing one on a hankook race car. But decided not to go ahead with it haha
1167417_768541539826874_1796915530_o.jpg\
1167417-768541539826874-1796915530-o-768
Ah, I see now.
That's the camber arm, not the knuckle. Just cut the arm down.
If you really want, buy a offset bush and offset the arm higher. It will clear easy that way.
Oh i forgot to say that pic is with a 8mm spacer that I was trialing
Oh thanks. I have no idea about suspension bits lol
Might look into the offset bush if it is also a cheap solution
Are there other bits I may as well change at the same time if I change the bush?
Suspension is stock except for coilovers, so would like to do a few things to improve the handling before the next track day
I know I probably need front and rear adjustable camber arms for more negative camber
On 12/11/2013 at 6:48 PM, Count Grantleyish said:
Isn't 40 profile bit too tall for Skylines? Most run 35 profile.
Yes it is a bit tall haha
Test fit of XD9's 18x10 + 18 265 Achilles tyre. Plenty of clearance
I don't mind Xd9s...
902351-768766373137724-320856539-o-76876
10750324-958603354154024-226993447194029
1401516-958603400820686-7929943015456419
  • Like 2
On 12/11/2013 at 7:37 PM, Count Grantleyish said:
How many wheels have you trial fitted so far?
Hehe just borrowing a friends wheel for now till i fix the issue
If anyone has any Ce28ns I can trial fit...
This is the clearance I have with the Xd9's 265/35 tyre combo
1000117-768792159801812-1283234871-n-768
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
