now for some big ass brakes and you could fool everyone!
till they see the interior that is :P
Yeah trying to stop spending on the car for now haha
Car looks great.
After having it for a while, how do you find the car's power delivery and driving characteristics at this power level? Would it be tolerable for a daily?
Hrmmm....Going from a sort of linear 280rwkw on the ss2 to a non-linear 350rwkw 3582.
ss2 definately beter for everyday driving- but i got bored of 280rwkw pretty fast
350rwkw is plenty push in back shit your pants sometimes kind of power
I think one of the new ss2's and bump up the psi to 22-24 for around 330-350rwkw would be great as a daily driver!
It dont need spacers. Looks great
But i want to be hektik
Great build mate.
Thanks!
  • Like 1
How did you manage to fix the gap between the bonnet and front bar dude?
OEM brackets lift the front bar up enough plus rubber piece in between the bonnet and bumper?
Its not 100% yet but pretty darn close just waiting on some inner headlight brackets
You need the GTR reo, outer and inner brackets then upper retainer and rubber then shell be right
  • 1 month later...
So this year I've decided i want to head back out to the track.
Just need to fix my heater hoses and fit an oil coolver.
In the meantime replacing my Tein HA suspension to BC ER Coilover 9kg front 7kg rear
10613155_1001739843173708_15585443999663
  • Like 1
I went to go back and re-read this beautiful build, and maybe it's just me, but it appears a lot of the image links are broken?
Dang, that is going to be a pain to relink them all :/
Edit attached some images back up
Noooooooooo Tony!! Return them and get Tein Street Advance!!
I only got them for $750, this is still a budget build
Works for Richo so must go ok!
No big deal! I believe the Street Advance is better than the BC's, but not a HUGE difference between the two if you're only paying $750 for BCs!
Where can one buy BC's for $750?
Edit: NVM read up..
Edited by colourclassic
lol at budget build :wub:
Edit: NVM read up..
So the GTR coilovers didnt end being the best fit, as they are quite shorter than the GTT ones.
Returned to seller, so send me a PM if you to re-buy them
Its not too bad
Incl the repurchase of the car after written off, I would estimated the whole engine rebuild, body kit and respray, wheels, everything to get to where its at would be about $20k or under
I take it they were for R34 GTR? Other wise where do I get those Tiens from at $990?
Yeah GTR ones, which are a bit shorter
Teins from here:
http://performance.fulcrumsuspensions.com.au/
  • Like 1
Oil cooler has arrived
15row Greddy style Oil cooler from Vulture Motorsport.
Will be getting this installed with braided lines and a Greddy thermostat at Scotty's on the weekend. And maybe some ducting
Current temps where about: 95c just normal highway driving
And would take about 2 laps at Sandown to go past 120c
1781890_1007245225956503_563054127752141
Ducting makes all the difference if you're installing it in behind the bumper bar, trust me on this one :P
Without it you might make 3 laps and then have to cool off. Duct it properly and you could manage to go the entire session as hard as you want, assuming it's an efficient setup.
  • Like 1
Thanks for the Info!
Lets hope Scotty is up to the task!
In other news received these today, as I think the stock rubber ones are getting really old. Don't want to risk it on the track!
1463691_1008401049174254_279332924449044
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
