1 hour ago, blah_blah said:
Small update
So a few things. Need to fix the rear camber so ordered hard race rear camber arms.
Also rear end bearings were gone so apparently it is easier to order a full HICAS delete kit:
Over the next month will also do a custom cooler piping job and custom airpod box.
May also do Sandown this month but not sure yet
Nice kit! Something to add to the shopping list perhaps is rear traction arms, they'll help counter bump steer in a lowered setup. Here's some more info from when I was looking into that: https://www.sau.com.au/forums/topic/448509-wheel-alignment-question-car-feeling-more-skittish/?do=findComment&comment=7570413
Re Sandown, I'm pretty keen on the Tempered session on Australia Day, might see you there :)
Thanks! Good to know re traction arms! trying to keep mods minimal and concentrate on seat time and a reliable car from here tho.
Looks like im out for Sandown, but if your in let me know and i might pop by
On 1/10/2017 at 10:13 AM, Leroy Peterson said:
You still got HICAS? That shit should be illegal.
Do broadford in March with me. (If I'm not flat out with work)
Hrmm i only just get back from Murica in March. My car wont really suit Broadford lol
  • Like 1
12 hours ago, blah_blah said:
... trying to keep mods minimal and concentrate on seat time and a reliable car from here tho. ...
Smart plan! I'm hoping to do the same :)
I have signed up for Sandown on the 26th, fingers crossed all of last year's issues are fully sorted. If you end up dropping by look for the silver 34 sedan with black wheels :)
On 1/9/2017 at 7:55 PM, blah_blah said:
Small update
15873030_1547821361898884_10733021024492
15873272_1547821401898880_30811198885244
15941199_1547821385232215_89167324168121
Awesome thread! Car looks brilliant.
Where did you order your hardrace parts from? I can't seem to find many sellers these days now
Will do!
Got my hardrace parts via Topstage :)
  • 4 months later...
ZZzzz not sure why my fb links are always broken.
Anyway just a small update doing a xenon projector retrofit atm.
Purchases some 2nd hand lights
18767390_1717804664900552_33819629814147
1st time baking in oven not great lol
18814235_1717804721567213_37423389454635
2nd time much better:
18835502_1717811568233195_61118913565889
Xennon kit has come through:
18920233_1717812311566454_36114802786519
18813545_1717804618233890_63794632662224
End product in a few weeks something like this without the red:
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
