Just some bits and bobs:
Rear housing off the rear of the turbo ready to be sent to HPC Coating:
920490-637780412902988-970992184-o-63778
476217-637780396236323-898132014-o-63778
Nitto H-beam Rods:
904732-637780426236320-204623195-o-63778
397927_637780426236320_204623195_n.jpg?o
ACL engine gasket, Nitto Head gasket and Cometic exhaust manifold gasket:
476352-637780436236319-1523615168-o-6377
Bolts and Studs:
922473-637780466236316-2099220442-o-6377
Where did you get your machine work done? They didn't use a torque plate for bore honing?
My mate at JDM Garage is doing the engine rebuild.
In regards to the torque plate, its a bit over my head but after some discussions involving the actual benefits of a torque plate we decided not to go with it. The theories were quite interesting..
Seeing the Nitto gear on display at the JEM tech night was good, having them explained etc was awesome! Such quality :woot:
Yeah I saw pics from your NSW JEM meet. Was very jelly
Really good motivation for ya ;)
Looking good tony! When she due back on the road?
Yeah this i would like to know! Should be good :yes:
I estimate that the engine will be finished with everything back in the car in about a month.
Then another month sorting out the VIV (As the car was written off) and Road Worthy Certificate.
We might have some issues with the engine gaskets. As we were supplied with a ACL Rb25det gasket kit not a neo one. Even though we were assured it would fit.
I already know the plenum gasket is different, among a few other things as well.
Anyone know where to get them quicksmart? Apart from getting them via Nissan or Japan?
I can get a full genuine Neo engine gasket kit from Amayama for ~$350. But its a 3 week wait and I would get a whole bunch of other gaskets I don't need.
Edit: Just emailed Andrew from Kudos to help me out
On 4/30/2013 at 9:31 AM, 34GeeTeeTee said:
I was going to say Nitto mentioned they had them in stock at that Tech night but i assume you would pay accordingly....
A complete Neo engine gasket kit? That's interesting, didn't know they made them :(
I got the Nitto Headgasket though
In any case getting a genuine Nissan gasket kit off Andrew @ Kudos motorsports. So props too him!
Also these just arrived today
Complete Genuine Nissan Heater/coolant hoses & thermostat for the Neo:
478539-640102536004109-1886260594-o-6401
Prett keen to hear the theories if you'd like.
I will ask and will post when he gets back to me :thumbsup:
In the mean time, just out of interest
Weight of:
Nitto rod & Cp piston = 944.4grams
Stock Neo rod & Piston = 1134 grams
So a saving of about 1.14kg in the engine by using these parts
923399-641111785903184-1666426285-n-6411
Weight of:
Thanks for doing that :thumbsup: Interesting!
Had a quick chat to the engine builder and most of it went over my head. But he said his happy to chat to you about it at any future SAU meet, whenever you guys see each other :thumbsup:
In other news:
Nitto crank collar fitted:
310016-641607085853654-585734729-n-64160
Grub screws fitted to the crank collar, crank is now finished ready to be sent for balancing
482642-643106392370390-976179864-n-64310
945469_643106305703732_634273494_n.jpg?o
Also weighed the CP pistons and Nitto Rods to see if any weight adjustments needed to be made:
Nitto Rods:
1. 516.0g
2. 516.5g
3. 515.8g
4. 516.3g
5. 516.5g
6. 515.8g
CP Pistons
1. 426.8g
2. 426.8g
3. 426.5g
4. 426.8g
5. 426.6g
6. 427.1g
Block has been peppered:
919436-652171204797242-1485976487-o-6521
976373-652171188130577-1145389192-o-6521
Also genuine gaskets arrived today. Many thanks to @kudos.motorsports
944737_643106412370388_654822655_n.jpg?o
  • 3 weeks later...
On 5/22/2013 at 7:43 AM, Leroy Peterson said:
any updates?
Coincidentally yes I do!
Block and head is all finished. Just waiting for the crank to finish balancing then its just assembly and to put the engine in!
Hopefully only a few weeks away and the engine will be running in the car!
248104_651224698225226_708561579_n.jpg?o
Also have received my brae manifold, turbo housing and dump pipe all HPC coated. Only a one week turnaround:
All nicely packed in delivery by HPC:
977959-651224998225196-118991215-o-65122
976922-651224784891884-1119670989-o-6512
965739-651224798225216-1967956834-o-6512
967093-651225041558525-194920362-o-65122
980496-651224864891876-518724312-o-65122
977990-651224951558534-758279348-o-65122
For those that are interested we also decided to lay the "torque plate" theory to the test as we had some spare time. We torqued the head down to 80ftb using arp head stud, flipped the block over and measured the bores. No distortion was present and the bore gauge still read 0.
970616_651224994891863_216125180_n.jpg?o
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
