Good progress.
Not sure if this is a silly question... but because your ECU, AFM, turbo, injectors, cams etc. are all remaining, will you need to get a new tune?
(but you'll obviously get one eventually to ramp up boost and break 300kw)
Super spaghetti manifold :P Brae does some awesome work ;)
A bit better than my other china manifold :/
Even though its heat coated I will also heat wrap it, and maybe also put a heat shield over it
Good progress.
Probably isn't really necessary. Since all supporting mods are essentially the same.
Will still be doing a re-tune though.
Previously made 280rwkw. 20 psi dropping down to ~16psi.
Have now got a stronger actuator off Stao and have been advised that the max psi prob is ~23psi.
So will be going for 23psi and hoping only a few psi drop off at redline.
In saying all this with the amount of work done to the head I have been advised that my engine might be too much for my little turbo. Something about the engine overspeeding the turbo or something from memory
So will be interesting what power it will make.
Yep, If you find the thread with Marks low mount TS 6Boost, there are some good pics of the heat sheilds on there! They look pretty stealth!
And yep, i would be retuning or touch up tune with ANY change ;)
We'll I thought the motor would be finished by next week
But its actually going to finish today lol!
Nitto Rods, CP pistons in and ARP headstuds
976306-652171261463903-729962474-o-65217
420201_652171141463915_1467250267_n.jpg?
969611_652171204797242_1485976487_n.jpg?
Nitto headgasket on:
931405_652171234797239_298430958_n.jpg?o
The head on:
965042-652171344797228-490885296-o-65217
268907_652171344797228_490885296_n.jpg?o
Shims on:
936876_652171421463887_639160525_n.jpg?o
And wola, nearly finished!
966633-652171551463874-129009712-o-65217
971841_652171451463884_2115204859_n.jpg?
981366-652171451463884-2115204859-o-6521
Small update
Bit of cosmetic changes and trial fitment.
Over the next few weeks when we have time it will go back in the car
I was about to say "Y U NO COAT ENGINE???" But then saw this! Nailed it! Epic manifold from Brenton :thumbsup:
So sorry to hear about your car getting stolen and treated the way it was.
But hey! Things are looking good now, your build is bloody awesome and can't wait to see it finished and see you out at Sandown and Winton :)
On 5/28/2013 at 10:01 AM, dkbcleaner said:
Wow looks awesome!
On 5/29/2013 at 11:26 AM, LANDSCRIBBLE said:
Man what a mad build! Love it :D
Thanks guys!
Minor update before the motor goes in:
I remembered how much of a pain in the arse the standard water lines to the turbo were to fit on a aftermarket turbo.
So the workshop made some braided water lines with speedflow fittings:
Old water line vs new
Test fitment
I may also be keen for a set. I purchased some Kando lines but they use banjo bolts and it really doesn't work well at all. Yours look like they screw into the block directly rather than use a banjo bolt.
How much would a set of those lines set me back? PM if you want.
do like those water lines.
Yeah they do look quite nice :D Makes a turbo install much easier too!
Just the cost of the parts was ~$120 for 7 speedflow fittings and $27 p/m for the hose used. Used about 1,5m. These are quality parts too, not a yum cha brand.
There is a fitting that gets screwed to the the block, and then the line connects that that fitting. Perfect fitment
If you guys would like some I can see if he will make some for you lot :thumbsup:
Cost will depend on the fittings you need though
I'm definitely keen, not right now but in the near future. Would need whatever the stock turbo uses for now so makes it easy enough, your highflow would use the same fittings?
No worries!
Pretty sure it's the same fittings, as I was using the stock water line fittings on the Ss2 turbo when I had it on
I would also be down for a set for sure, do speedflow do black fittings, as the blue and red anodized look nice but easy for the cops to pick up on, i would rather keep everything stealth if possible! I checked with Stao and yes the highflows use the same size fittings as the standard turbo so myself and Miguelone would need exactly the same fittings as yourself.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
