Hi all,
Got my engine rebuilt forged internals etc standard head just with 256 cams
Cranked the engine to build oil pressure, cranked it for like 5secs got 80psi pressure, started the car up and straight away lifters started tapping off its head,
Before anyone says take it to engine builder, I will on Monday when he open but been weekend Ill like to try work out what's wrong with it,
Nitto oil pump, still running VCt, blocked middle, 1.5m rear restritors,
Only thing I'm thinking is engine builder didnt do cleanances right? But I highly doubt it,
Bad lifters? How can I tell?
https://www.sau.com.au/forums/topic/419630-urgent-help-needed/
Hydraulic lifters sorry,
Thought that as well, we had it at normal temps, (half way) took it just for short drive under 3000rpms and still ticking,
It seems to rev slow like it revs and the come down revs is slightly sorry
I was so nervous to start it as I have had so many issues in regards to work that was done on it, I didn't wanna start it... But just from
How loud they are and all the time doing it, I didn't wanna risk driving it and causing more damage, but yes they have been out of the motor for about 7months dry,
If its a fresh build you shouldn't be idling it or taking it on a light/brief drive.
You should be seating the rings or you'll stuff the build entirely. Tow it to the builder/dyno Monday and don't keep starting it now. All you should do on a fresh build is let it run for a couple mins just so you find any potential water/oil/air leaks etc.
yeah fair things i wanna check like cam cover just to make sure its not hitting it was late yesterday arvo 5pm and once i heard the noise i didnt want anything to do with it for the day was a let down she packed up closed the shop lol
Was the previous engine blow up a spun bearing by any chance??
It's so common this happens when a small bearing particle blocks the head oil feed from the previous blow up and you end up with stuff all oil to the head.
It's bloody hard to have the galleries cleaned out perfectly unless the original restrictors are removed.
A lot of engines I've seen built by various Motorsport teams like the supercars have external feeds to the cylinder head with inline filters to prevent this happening.
Hole bottom end was destroyed in the old motor, started again with block and crank, only think that didnt change was the head, but engine builder knew what happen with old motor and I told him to wash the head and he said he would do that,
Only thing that was used from the spun bearing motor was the head, lifters and cams? Could these of been f**ked from the old motor? I asked the engine builder to check everything to make sure it was all good to go back in
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
