Just putting this up to see if anybody is interested in it at all.
this car is a jdm pig. really more suited for a track car.
R32 Gts-t rb20det 156000kms original
will sell with 6months rego no rwc or can sell un regoed for less
Note: has had rear right end damage but will be covered buy widebody rear gtr style fenders!!
mods.
-hks coilover front
-cusco rears
-shimmed lsd
-lock spacers
-nistune ecu tuned to 170rwkw at 12psi it was safe tuned cause it was my daily
-walbro 255lph fuel pump
-s2 rb25 turbo
-turbosmart boost t
-apexi pod filter
-FMIC
-nardi wheel
-mod plated for a half cage and 2 seater
-new solid rear bushes
-adjustuble camber arms front and rear
-gtr bonnet (alloy)
-gtr front bumper
-m spec side skirts
-m spec rear pods
-gtr fibreglass rear quarters not fitted in photo there just white primmer
comes with:
brand new alloy dual core radiator with twin thermo fans and custom alloy shroud... not fitted
brand new 550cc densos still in plastic... not fitted
brand new z32 afm and tomei plug still in box.... not fitted
does not come with the black grids in photo comes with drit tekz 17x9.5 +18 black but bombed silver with 595s up front and cheap rears can come with the grids for extra but there brand new never been driven on
and olso have a pair of brand new bride lowmax fixed back seats that i can add for extra
comes with most interior parts but have the rear seats striped out atm car is ruff around the edges but is built to slide not turn heads.
asking $7,000 as is have over 10k worth of receipts in parts over the last 3 months so priced for mods sake.
reason for selling is i wana put the money into my s15
plenty more info just sms me for any details. 0421314199
Edited by jdm32r
https://www.sau.com.au/forums/topic/419660-r32-drift-pigdaily-for-sale/
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
