Hey boys, as in topic title my drivers side drive shaft boot is wide open and I suspect it's been like that for a while as grease is all over suspension arms.
The question is what is the most cost effective way to repair the boot and where or to order whole new drive shaft from Nissan?
Anyone had this problem?
I have inquired at local drive shaft repair joint where for more common cars you can simply get a swap for a repaired DS, not for Stagea and he has never seen one repaired?
Thanks
David
https://www.sau.com.au/forums/topic/419675-2002-m35-drive-shaft/
The boot isn't that hard to change man I had never done one before and it only took me like an hour to do. So was not to bad, but if you find the part number let me know :-)
Are you talking about the inner boot or outer boot? The guy at the repair shop said that he could maybe find the match but inner is the problem???
just go to your nissan dealership and order some dont use universal ones as they aren't as good.......... ill look part numbers up or Daleo should know LOL
found this too.......... (note drivers side inner and passengers side inner are a different part number, but outsides are the same)
also try the search function next time as this has been covered a few times :)
Sorry man didn't mean to bring up stuff being covered, Thanks for the info and I'll try nissan first but part numbers will make it easy.
Cheers
Dave
Notice the part for the boot has a star, not a part number. Nissan ordered some of the other part numbers in for us but none were the inner boot. A driveshaft shop would be your best bet. Or there are also Various Nissan boots on ebay that look similar, could be cheap to try and order one off measurements...
Just a quick update on this issue,
After all the searching and calls to nissan I've decided to do it the easy way which is called Greg from Autosport Kirawee (02 9521 1388) who said yep we have them in stock and all done cleaned regreased and fitted within two hours for a resonable price what a service.
I have used them before for gtr work (4wd didn't work) very familiar with imported cars and performance kind of work.
Would highly recomend them especially if you not DIY kind of guy or just busy.
Dave
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
