markos Posted February 10, 2013 Share Posted February 10, 2013 Had a few lifters try and qualify for ProRawFive, which is invitation only, in November, $10,000 prize money Here are the ones who did best Rebecca Gleich went 115/65/145 - 325kg@56kg Eddie Dargham 182.5/110/240 - 522.5kg (first ever comp) Stelian Tchapkanski 180/152.5/215 - 547.5kg Evan Magiras 220/130/275 - 625kg@94kg Zoran Javkoski 235/140/290 - 665kg@113kg Martin Nguyen 232.5/150/285 - 667.5kg@77kg Daniel America competed but couldnt bench, he tore his pec severly a couple of weeks ago He managed 220/20/265 - 505kg , he just did a token empty bar bench. His bench PB is 167.5kg Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/ Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746113 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746115 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746118 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746121 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746125 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746126 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746130 Share on other sites More sharing options...
markos Posted February 11, 2013 Author Share Posted February 11, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746131 Share on other sites More sharing options...
NickR33 Posted February 11, 2013 Share Posted February 11, 2013 great lifting all round Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746191 Share on other sites More sharing options...
rev210 Posted February 11, 2013 Share Posted February 11, 2013 awesome! Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6746638 Share on other sites More sharing options...
KezR33 Posted February 12, 2013 Share Posted February 12, 2013 Hey Markos, Just wondering why did Martin walk the weight out of the monolift? Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6748276 Share on other sites More sharing options...
markos Posted February 12, 2013 Author Share Posted February 12, 2013 Why does Martin do a lot of things lol I have no f**king idea He is not a fan of the mono or the 35mm squat bar. He hasnt trained on it enough for this reason. Everyone else loves it. He is now using it exclusively Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6748445 Share on other sites More sharing options...
markos Posted February 12, 2013 Author Share Posted February 12, 2013 Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6748961 Share on other sites More sharing options...
TTT Posted February 12, 2013 Share Posted February 12, 2013 hmmmm.. hot legs indeed Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749006 Share on other sites More sharing options...
Birds Posted February 13, 2013 Share Posted February 13, 2013 hmmmm.. hot legs indeed Martin's? Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749207 Share on other sites More sharing options...
-FIGJAM- Posted February 13, 2013 Share Posted February 13, 2013 question about the bench lifts.... isnt that giant curve bad for the actual body and bad technique or form? Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749223 Share on other sites More sharing options...
TTT Posted February 13, 2013 Share Posted February 13, 2013 Yes Martins.. I'll see if Markos wants to tell yesterdays story about Martin here.. lol The idea is to get your shoulder blades in and down. this pops your chest/rib cage out and up. then pushing with your legs pushes you up on to your lower traps area. This means that your shoulders/scapulas are in there saefst and most powerful state. Your spine isn't loaded. Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749257 Share on other sites More sharing options...
-FIGJAM- Posted February 13, 2013 Share Posted February 13, 2013 Thanks TTT does it help hit target the chest more or is the benefit more for heavy lifting? if that makes sense.... Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749311 Share on other sites More sharing options...
TTT Posted February 13, 2013 Share Posted February 13, 2013 well... both in a way. in powerlifting, the aim is to lift the most weight. so you do whatever you can with in the rules to get in to a position to lift the most weight. eg. Using a close grip bench with your elbows flared, back flat, lowering the bar to the middle of your chest will probably built a bigger chest. But using a wider grip, bringing the elbows in, arching your back, and pumping your chest up and lowering the bar to your lower chest (which will be the highest point when your back is arched) will probably allow you to lift 1.5 times more weight due to recruiting the triceps and delts more, your lats some, and with the hands wider and chest up, the range of motion is also shorter. having said that, lifting heaver weights leads to more strength and size. In powerlifting, as I said, the aim is to lift the most weight.. so powerlifters do it to lift more weight rather than to become chesty brahs. you'll see it in squats and deadlifts too. squatting with a wider stance gives you more power once you get used to it. squatting with a narrow stance means the range of motion required to get your hips below parallel is longer and doesn't use the hamstrings much. bet you get massive quads. wide squatters get to use quads, hips and hamstrings. end up lifting more weight. Deadlift - some lift conventional (feet close and hands outside of feet), some lift sumo (feet wide out and hands inside right to the edge of the knurling) reduces the range of motion, but need different muscles used. Link to comment https://www.sau.com.au/forums/topic/419683-prorawfivequalifier/#findComment-6749347 Share on other sites More sharing options...
