Hi Everyone!
(Please reply to this thread, PM or sms 0411 497 358 if interested - thanks!)
Up for sale is my Skyline I bought from C-Red back in January / February 2003 (from memory). I originally bought this car as a daily driver and then it became my project car. Over the years I have added bits and pieces to it, with an aim of getting it tuned, and then taking it down to the drags or doing some track days etc. However, life kept me busy, and I have never managed to finish it off.
Subsequently this car has never been raced or tracked in any form – just street driven at a moderate pace (not a fan of street racing, speeding etc.). It has always had the stock turbo on it, with the boost controller switched off most of the time, so it is just running a wastegate pressure of 7psi that creeps upwards due to the intake and exhaust modifications. All it really needs now is a tune and you could leave it as is, or modify it further, whatever you desire.
A couple of years some fool dented my passenger door at Bunnings Carousel. I fixed this, primed it, and painted it in acrylic paint – to the best standard I could. This may either be good enough for you, or you could get the door or whole side of the car re-sprayed and blended. Besides that everything else is great for its age.
The tyres on the car are worn, but I have some second handers off my brother’s XR8 in my garage that you can have if you buy the car. They have slight camber wear, but will be good to go otherwise.
Details are as follows:
1994 R33 GTS25t
- Blue green effect with gun metal grey lower paint.
- Around 137,500 km (had around 86,000km when I bought the car nearly 10 years ago).
- Oil and filter changed every 3 months regardless of distance driven.
- Timing belt, water pump and idler pulley changed at 100,000 km.
Engine
- Apexi Super Suction Kit (Apexi Power Intake and aluminium intake piping).
- Z32 air flow meter.
- Greddy V-SPL front mount intercooler.
- S15 480CC injectors (cleaned and flow tested prior to installation).
- Greddy oil catch can high pressure side.
- Secondary oil catch can low pressure side.
- Greddy washer bottle.
Gearbox
- Heavy duty clutch (installed by C-Red – unsure of type, brand etc.).
Exhaust
- 3” stainless steel exhaust from turbo back (X-Force front pipe, C-Red cat back, decat in at present – have got X-Force 3” high flow cat that will also come with the car).
Electronics
- Apexi Power FC and hand controller.
- Greddy Profec B Spec II electronic boost controller.
- Apexi SAFC NEO (acting as a monitor only as Power FC has replaced it).
- Apexi EL2 mechanical boost gauge (black faced).
- Innovate Motorsports LC-1 wideband oxygen sensor, controller, gauge, laptop cables, software.
- Greddy turbo timer.
- Cyclops dual stage shock sensor and immobiliser with boot and bonnet protection.
Suspension
- C-Red front strut brace.
- Mid-chassis brace with fire extinguisher attached.
- OEM rear strut brace.
- Lowered Springs
Rims
17” Speedy Holotype-R with 235/45 tyres on them.
Stereo
- Alpine head unit.
- Pioneer 6” splits.
- Pioneer 6x9” 5 ways.
- 2 x Pioneer 12” subs.
- 2 x Sony amplifiers in custom shelf next to battery (four channel and two channel).
Interior
- Selected plastic trim sanded, primed, painted and clear coated colour of car.
Windows
- Tint-a-Car Ash Cool.
  • 1 month later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
