Scare monger!! Have you seen what a grinder will do , not to mention in the hands of someone who doesnt use one often.
Yes, grinders are great at cutting things, principle design function if I'm not mistaken, I'm fairly sure an airsaw won't just bounce off flesh if you get in the way........they just stop quicker, but can still give a decent hack. Plus the thing is physically awkward to use in the confined space.
People need to take some responsibility for their actions, I suggested what worked perfectly fine for me as I'm not a complete retard and treat tools with respect, and if I've not used one before I'd get someone who is skilled at using it to do the job. Hence why if someone posted "the best way to do the job is on a lathe" I wouldn't be running out to give it a crack, as I have NFI how to use one and would end up getting clocked by a solid piece of metal.
Personally I'd be more concerned about him using a stanley knife to cut the soft foam, they don't know when to stop and so many people have bad technique it's not funny.
I gave him the easy rat and peanut butter option....
Did woodwork in school, everytime I used a lathe, I'd picture the tool I'm using being flicked around and stab myself in the head :unsure:
Though an easier and cleaner option I would think to be is just simply use a Stanley knife with blades like this:
388197d1345983627-autopsy-suicide-guy-st
Very clean and precise cut, those blades in the picture are much more stronger and firmer to work with compared to your packaging/box cutting knifes. Though it may take some time to slice through hard plastic (unless there is a metal frame that I don't know of).
I'd rather clean slice my finger off with that than having bits of me ending up like a meat pie.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
