  • Replies 52
I'm getting bloody sick of missing out on 350z springs! every time I see them for sale they've already been sold :(
glws
I'll have some Tein H-Techs for sale soon?
glws
Just get coilovers, cause you'll get sick of springs as well..
im so keen on htechs if itpesaf passes
no worries - remind me when the time comes.as in - if i put them up for sale and don't contact you first, remind me of that.
embarassingly, i am installing coilovers, but probably going to have to set them higher than the h-techs sit - which will mean practically back to stock height. moved into a new house yesterday with a massive garage and a carport - and my car can't get in the driveway!!!!! exhaust flange hits coming up off the street, and then the driveway dips down and my nismo bar hits the concrete. FML.
How low do the h-techs sit? will they be ok with the stock shocks?
ps. If it aint too low, and if they sit fine on stock shocks please pm me! Only prob is I'm in Adelaide :( but I'm happy to pay postage.
I have a feeling those H-techs sit a little lower than 1''
You'll need to upgrade your shocks in the near future after putting lower springs on your car as it puts more pressure on them and shortens the life. That's why most people skip straight to adjustable coils as decent quality shocks for our car can see you paying up to $500 for a set..
But surely the V35 shocks and 350Z shocks are the same? (I'm not talking about the H-techs, but moreso in my case). Changing to 350Z stock springs shouldnt affect the V35 shocks as they're the same as the 350Z? Although I guess weight difference is an issue.
Incorrect. They sit 15mm lower at the front and 8mm lower at the rear. They're designed specifically to be used with stock shocks, and to give a slightly lower ride without sacrificing comfort.
http://www.z1motorsports.com/350_g35/product_info.php?products_id=2968
You might be thinking of S-Techs which are lower again. As per my other thread, I dunno how people run much lower. Stupid long wheelbase :angry:
Kinda getting off topic here, but if I wasn't going to be running such large/agressive wheels I would stick with these springs and just replace the tired shocks. Didn't want to take the risk of not having coilovers for the sake of adjustability and fine tuning the clearance.
Incidentally, I have 350Z shocks in the rear of mine and it sits the same as the stock shocks based on photos - so I'd hazard they're the same shocks - and Nissan counters the extra weight of the V35 with taller springs - which explains why 350z springs lower the car.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
