Hi Guys
I've bought some 33 gtr shocks and springs but they have no strut tops to keep the springs in
I ideally want to create another whole set you i can set the bilsteins low and keep my current springs as they are
So the big question, will any other strut tops fit the gtr shocks?
https://www.sau.com.au/forums/topic/419752-strut-top-options/
You will want stagea strut tops, not GTR. Definately for the rear and probably for the front as well, because they have to fit into the chassis OK.
I think your best bet will be a set of standard ones, aftermarket (if you can find them) is likely to be expensive, and be "pillow ball" which is a large bearing at the top which will probably flog out quickly in road use and start knocking, sending you crazy
Really? Pretty sure its already got gtr shocks in it (rs4s) as they are impul (i suppose that doens't mean much tho)
i'd run the numbers into FAST but I'm on my laptop for the next week
maybe! the strut tops are probably standard stagea in there now....the rear in particular has an oval strut top and I can't see how a gtr top would fit. It's not the whole shock that changes, just the strut top/spring mount
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
    • Everyone wants an ECU they can plug onto their engine, modified or not, and put of the box it just runs perfectly like a brand new modern engine straight off the production line. Too many people just don't understand things like the base maps are as you said, just to give a starting point, and then you need to spend time getting it right for your vehicle.   I wonder if the people wanting it are the same ones who'll just buy a chip for a "stage 2 tune" online and then wonder why their engine blew up...
    • Quite possible! And well worth checking out, as it will be more durable than paint
