  • Replies 1.7k
Posted Images
THE SNEEZE
A man and woman were sitting beside each other in the first class
section of the plane. Suddenly, the woman sneezed, took out a
tissue,
gently wiped her nose, and then shuddered quite violently for 10
or 15
seconds.
The man went back to his reading. A few minutes later, the woman
sneezed again, took out a tissue, gently wiped her nose, and shuddered
quite violently; as before.
The man was becoming curious and concerned about the shuddering.
A few more minutes passed and the woman sneezed one more time.
Again she took a tissue, gently wiped her nose, and shuddered violently. The
man couldn't restrain his curiosity. He turned to the woman and said, "You've sneezed three times and this has resulted in noticeable shuddering spasms. Are you all right?"
"I'm sorry if I disturbed you," the woman replied, "I have a rare condition; when I sneeze, I have an orgasm."
The man was a little embarrassed, but even more curious and said,
"I've never heard of that before. What are you taking for it?"
The woman looked at him and said.........
Wait for ittttt...................
" Pepper."
THE FLY.
There's a fly circling 6 inches above the water, in the water theres a fish. That fish thinks if that fly drops 6 inches he will eat the fly. Behind the fish is a bear, that bear thinks if that fly drops 6 inches the fish will grab the fly and he will grab the fish. Behind the bear is a hunter, that hunter thinks if that fly drops 6 inches the fish grabs the fly, the bear grabs the fish he will shoot the bear. Behind the hunter is a mouse, that mouse thinks if that fly drops 6 inches the fish grabs the fly, the bear grabs the fish and the hunter shoot the bear he will grab the hunters sandwich. Behind the mouse is a cat that cat thinks if that fly drops 6 inches the fish grabs the fly, the bear grabs the fish, the hunter shoots the bear and the mouse grabs the sandwich he will grab the mouse.
Well the fly drops 6 inches the fish grabs the fly , the bear grabs the fish, the hunter shoots the bear and the mouse grabs the sandwich, the cat went to grab the mouse but fell in the water.
What the moral of the story?????
If you drop your fly 6 inches u get a wet *****.
Anti Schapelle Campaign
True or not true???
Read the emails below from the bottom up.
Yup... But it was meant to go to Sydney but it didn't get taken out by the baggage handler so it came back..
-----Original Message-----
Sent: Friday, 10 June 2005 11:35 AM
To: Casey Kerr
Subject: RE: Recent Application for Junior Receptionist
So ya sayin she knew it was in her luggage on the way to Sydney
Sent: Friday, 10 June 2005 11:30 AM
To: Chris Saliba
Yup.. Also my boyfriend works with her cousin and my ex knows her..
They are one of the biggest drug dealers on the coast... And Sydney...
The bag was meant to go to Sydney cause there other cousin works in Sydney airport baggage but got fired before they knew...
But then again.. No one is really going to hear the true story!!!
Sent: Friday, 10 June 2005 11:21 AM
To: Casey Kerr
Casey, Is that Corby thing for real...Do u know this bloke????
_____
I was diggin through some stuff in my office last night and I came accross a cd with photos from xmas 2001. Look who happened to be joining in the festivites... yep Australia Most Infamous Boogie Boarder.
Damn* I keep good company.
Take Note:
Photo 1 - Keep an eye out on the coffee table for some incriminating evidence (in fact I think I might submit this photo at her trial as Exhibit B... after the big f*ck off bag of we*d)
Photo 2 - I think thats the same face she had on when they opened her bag up in Bali. DAMN*.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
