Second round of the Motorsport championship for the year
Entry
https://secure1.ilisys.com.au/wrxc/motorsports/Introduction.php
Sup Regs
http://www.wrx.com.au/ms/Current_Supp_Regs.pdf
Haunted Hills Sat 2nd March
WRX Vic
Location
http://goo.gl/maps/hhiQ6
License Requirement
AASA
https://www.sau.com.au/forums/topic/419780-haunted-hills-sat-2nd-march/
Looks awesome fun! How is the grouping? In the vid looks like you do one lap than.. do you go back around wait in line and go again..?? Or is it grouped like other track days so you go out in sessions and not as many people in line?
Yep, not listed yet.
Generally $85-110.
Haunted Hills is a hill-climb and works differently to a track day.
Line up in number order, do your approx 60 second lap. Park the car, line up again in 25 minutes when all the car have gone through.
Generally get 4-7 runs during the day.
You'd be surprised, it's a good fun day and the time between runs seems to go by quicker and quicker during the arvo.
I highly recommend give it a go at least once (I've only been once, but definitely keen to go again).
to add to Jarrod's comments, it's the track undulations that make it a different experience, plus if you're not tinkering between runs, there is the soche at the top of hill, looking down on other runs - you get to see nearly all the action.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
