HH is a great track but I think wrx price and non figure 8 may have killed it on this occasion.
For me, I'm looking at msca sandown 10/3 or tampered winton 11/3, as I do track days for exp (& cross fingers pbs) not points.
Hope this doesn't kill off people going to HH, it's definitely worthwhile.
hmmm, wasn't going to go but In Taralgon tommrow so might stay over any punt the Allroad around for some easy points in Std AWD. Does 2.6TDI quattro qualify? LOL
think that sort of monster will put you in Open class...
We at Winton on the 14th of April with rexy, you can collect points then :yes:
Then off to Sandown with Alfa (which will beat the living shit out of the MSCA day) on the 6th of May.
Last MSCA I went along to at Sandown, 3 runs for the day. I think the guys had 4 runs at PI.
We had 7 runs at the last rexy PI and almost ran out of fuel at the last Alfa day.
Yep MSCA are a good bunch but they do run slowly.
I'll probably do sandown since my dad's competing and I have some things to test.
Like to keep an eye out for wrx, gcc, msca, tampered events, I try to do one a month :yes:
In case anybody was curious, they ran clockwise, clockwise figure 8 then short track. Fun track but with a few hairy areas where flooring it over a blind crest takes a bit of getting use to...
Surprised that nobody else from SAU turned up?
the white EVO 8 MR there was a SAU member..but yeah that it.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
