Looking at fitting harnesses in my stag as when cornering at speed you have to brace yourself a bit at the moment. Anyone else fitted harnesses? Wanting to keep it practical with useable back seats so was thinking either a double release harness. Original plan was to put a harness mounting bar behind the front seats but not found any for stageas.
https://www.sau.com.au/forums/topic/419782-racing-harnesses/
Yep I fitted a couple of Recaros from a Euro Honda or something - more comfortable than a race seat for my daily driver but heaps more control on the track. In this country (don't know about UK) if you fit a harness you have to be a member of a car club, run a log book etc.
Yeah reclining are ok. It's to do with cutting people out of cars. Harnesses have to have a red release button so can easily by identified and seats must recline so they can get you out on a spinal board. It's meant to come into affect in April, they tried about a year ago but realized none of the mot garages were prepared.
As much as it pains me; that's actually a very smart policy.
At least there's logical reasoning at play in the decision making process; rather than the usual "Don't do it or we'll fine you" mentality we have in Australia...
Providing you have a WC34 Stagea a relativly cheap and good looking option is a pair of front seats out of a R32/R33/R34 GT-R. I believe they bolt straight up!
Personally I wouldn't be using a harness on the street anyway. While you are strapped in you can't move your body to look around properly (ie checking blind spots while merging lanes and parking)
  • 1 year later...
Honestly I found I could corner much faster while held in with a decent seat - I have used an aftermarket bucket seat and also a Recaro from a Euro Honda and both gave excellent results. I suspect a GTR seat would be also be ok and would have the advantage of bolting straight in to the existing holes without the need for an aftermarket seat base and slider.. As part of my cert process I had to fit seat belt anchors to the transmission tunnel so pretty secure as well.
You do realize that the back seats have to be removed and the belts must go back as straight as possible so as when you go over you body weight doesn`t go on your shoulders >back , Cams stipulation read the regs also road authority.
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
