Amazing 200sx with not a dollar to sepnd.
Nothing to hide on this built motor, all inspections welcome.
This is what i mean by not a dollar to spend ....
Head:
Chemically cleaned, x-rayed, ported and polished
Tomei 280 degree inlet and exhaust cams
Tomei adjustable cam gears
Tomei oversized valves
Tomei valve springs
Tomei retainers
Tomei valve guides
Tomei Solid lifter conversion
Tomei rocker arm stoppers
Nitto multi layer head gasket
Arp Head stud kit
Bottom end:
Chemically cleaned, machined, x-rayed and full balanced bottom end
JE forged lightweight pistons
Eagle forged H beam conrods
ACL race series big end bearings
ACL race series main bearing
ARP main stud conversion
Engine externals:
850cc twin spray sard injectors
Stainless exhaust manifold
Garret GT35-66R ball bearing turbo
Tial 38mm external wastegate
Custom 3" stainless exhaust
Greddy type S BOV
Greddy oversize oil sump
HKS oil filter relocation and cooler kit
Braided lines and fittings
SX Fuel pressure regulator with
Oil catch can
Very aggressive lumpy idle that rocks the car but is not too loud
Black Plazmaman Pro Series FMIC
3'' heat coated piping.
R33 5 Speed gearbox with machined synchros for quick smooth gear change
OS Giken twin plate clutch
R33 diff and drive shafts
Balanced tailshaft
HKS coilovers, height, damper and camber adjustable
Endless 6 pot caliper brake upgrade still allowing the stock rims to fit
Slotted rotors
Adjustable suspension arms
Haltec Platinum ECU, 4 bar map sensor
Eboost 2 boost controller
A/C is ice cold
All power optioned
$26500 ONO
Located in Sydney
PM me for more details
Cheers Kris
