Man, I am posting like a demon today !!! (all of 2 post .. yes that is big for me..)
The question I have for everyone is a selfish need for more power.... I'm sure you can all sympathise with this..
Let me list what I have currently..
'Line R33 GTS-T '96 Series 2
Air pod
Intercooler
Full 3 inch Exhaust from turbo back
BOV (full-e sik m8)
Power FC ECU
Profec B boot controller
I'm on the market to get a new clutch and flywheel which will of course allow me to get more power at the wheels, but I am just waiting for that group buy thread start up again!!
Now I've spent a fair bit of my saved up pay packet, so now I am after power gains for as cheap as I can...
So without getting extravagant and buying a new turbo, what other modifications can I do to make more power at the wheels that wont break the budget? Is there such a thing as cheap power gains after I have done most of my stage 1 work already?
Be very interested in hearing people's experiences with modifying their cars and the budget they had to play with.
Look forward to reading!
Thanks fella's..
Giles
https://www.sau.com.au/forums/topic/41979-more-power/
Next step would be a set of HKS cams if you dont want to change the turbo! Also a bigger AFM might be a good idea as the pressure drop wouldnt be as much. Altho Im not sure how big they are on the RB25, but all I know is that the SR20 (50mm) is barely big enough for a kei class car!!
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859479
RB20/25 AFM's are 80 mm.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859491
Treat me like an idiot man ... (well not literally)
So each of the below; what is the benefit of each particular modification, how much on average would it cost to replace, what's installation like? time required, difficulty etc.. (i installed all of my other stuff so i'm not too fussed about getting my hands dirty) and what kind of power increase do you think i would get?
i'm still trying to pick up about modifying cars, so i'd appreciate it if you could play teacher for this one:)
cheers dude..
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859492
A cheap but worthwhile improvement is some shrouding around your pod filter, and some ducting behind the front bar to ensure that air is passing thru your IC, not around. Next i would look at some cam gears, then be happy with a very effecient, nicely setup car.
Outside of that if you want more power/driveability id be looking at a new bolt on turbo that will make use of your current exhaust and filter setup, and a new fuel pump.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859573
Thanks man... once again though, good suggestions but can you quantify any of it? like what type of power increase I might get, the cost of purchasing things and how hard to install?
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859598
Cam gears, depending on brand will set you back between $400-500, so once fitted and car tuned will likely to end up being just under $1,000. With the Pfc you may only see a 5rwkw gain, but you can get a bit more midrange and driveability from it.
The ducting can all be done yourself for about $40-50, just get some thin aluminium, some foam and go to work.
Power gains wont be huge, but you can be sure that your air filter inlet temps are low as posible with good shielding and ducting for the filter, and then your intercooler is workign to the best of its ability by ensuring that air is passing thru it, not around it. So for next to nothing you are likely to pick up some throttle response
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859620
An 8 degree celsius increase in air temp cost 5% in horsepower. So if it's 25 degrees admbient and the under bonnet temp is 60 degrees, then you would loose ...............
I am sure you can work it out for your self.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-860339
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
