Man, I am posting like a demon today !!! (all of 2 post .. yes that is big for me..)
The question I have for everyone is a selfish need for more power.... I'm sure you can all sympathise with this..
Let me list what I have currently..
'Line R33 GTS-T '96 Series 2
Air pod
Intercooler
Full 3 inch Exhaust from turbo back
BOV (full-e sik m8)
Power FC ECU
Profec B boot controller
I'm on the market to get a new clutch and flywheel which will of course allow me to get more power at the wheels, but I am just waiting for that group buy thread start up again!!
Now I've spent a fair bit of my saved up pay packet, so now I am after power gains for as cheap as I can...
So without getting extravagant and buying a new turbo, what other modifications can I do to make more power at the wheels that wont break the budget? Is there such a thing as cheap power gains after I have done most of my stage 1 work already?
Be very interested in hearing people's experiences with modifying their cars and the budget they had to play with.
Look forward to reading!
Thanks fella's..
Giles
https://www.sau.com.au/forums/topic/41979-more-power/
Next step would be a set of HKS cams if you dont want to change the turbo! Also a bigger AFM might be a good idea as the pressure drop wouldnt be as much. Altho Im not sure how big they are on the RB25, but all I know is that the SR20 (50mm) is barely big enough for a kei class car!!
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859479
RB20/25 AFM's are 80 mm.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859491
Treat me like an idiot man ... (well not literally)
So each of the below; what is the benefit of each particular modification, how much on average would it cost to replace, what's installation like? time required, difficulty etc.. (i installed all of my other stuff so i'm not too fussed about getting my hands dirty) and what kind of power increase do you think i would get?
i'm still trying to pick up about modifying cars, so i'd appreciate it if you could play teacher for this one:)
cheers dude..
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859492
A cheap but worthwhile improvement is some shrouding around your pod filter, and some ducting behind the front bar to ensure that air is passing thru your IC, not around. Next i would look at some cam gears, then be happy with a very effecient, nicely setup car.
Outside of that if you want more power/driveability id be looking at a new bolt on turbo that will make use of your current exhaust and filter setup, and a new fuel pump.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859573
Thanks man... once again though, good suggestions but can you quantify any of it? like what type of power increase I might get, the cost of purchasing things and how hard to install?
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859598
Cam gears, depending on brand will set you back between $400-500, so once fitted and car tuned will likely to end up being just under $1,000. With the Pfc you may only see a 5rwkw gain, but you can get a bit more midrange and driveability from it.
The ducting can all be done yourself for about $40-50, just get some thin aluminium, some foam and go to work.
Power gains wont be huge, but you can be sure that your air filter inlet temps are low as posible with good shielding and ducting for the filter, and then your intercooler is workign to the best of its ability by ensuring that air is passing thru it, not around it. So for next to nothing you are likely to pick up some throttle response
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-859620
An 8 degree celsius increase in air temp cost 5% in horsepower. So if it's 25 degrees admbient and the under bonnet temp is 60 degrees, then you would loose ...............
I am sure you can work it out for your self.
https://www.sau.com.au/forums/topic/41979-more-power/#findComment-860339
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
